Topic: ground loop issue (Read 2662 times) previous topic - next topic
tommyrosa
hi everyone
i've built myself a sequencer for my synth (little phatty) using an arduino mega.
it's an analog (sort of) sequencer that outputs voltage from 0 to 5 v.
everything works perfectly exept for when i hook up the seq to the synth. The phattys leds start flickering and moving by them selves and weird stuff happens. but this only happens when the mega is powered by a transformer, because if i power it using a usb cable everything works perfectly.
googling i found out that the synth behaves weird due to a ground loop. (i had to google what a ground loop was)
anyways i can't find a way to power the arduino using the ac to dc transformer . i thought of hacking a usb cable into a power cable but i'm not completely sure it is a good idea, plus i think i've read somewhere that the usb port on the arduino can only feed the board 5 volts or so, thus not enough for the arduinos needs (7-12 volts), and the last thing i would need is an arduino running low on electricity (it has 36 outputs to feed!).
can anyone please help me? it is only my first project so i might even be missing something very obvious..and it is also the first time i use the forum, so please tell me if i'm doing something wrong.
thks
MarkT
You'd better post the circuit diagram, the setup sounds complicated and a picture is worth a thousand words.  I'm particularly interested in how much power your circuit consumes and how much decoupling you have.
Grumpy_Mike
I would be surprised if it is ground loops but not if it were lack of decoupling:-
http://www.thebox.myzen.co.uk/Tutorial/De-coupling.html
tommyrosa
ok here are some schematics of the gate and voltage output section of the sequencer...
notice that each arduino pin goes high and low before going on to the next pin, so you'll never have two pins on the voltage or gate section high at the same time.
Grumpy_Mike
Sorry but that is not much of a schematic. You are having trouble powering it but there is no part of the schematic that shows this.
I assume there is something wrong with your power supply setup but this dosn't make it into the schematic.
tommyrosa
my poor english must have lead to some misunderstandings, i apologize.  :~
i'll try to explain myself better:
i haven't built myself yet a power section for the sequencer. i just use the mega's built in power jack or the built in usb port.
when i power the arduino from my computer using the usb cable, i have no problems at all and everything works perfectly.
instead when i power the arduino using it's power jack, the sequencer works fine, but when a connect it to my synth, the synth start's behaving strangely (this obviously should not happen, and does not happen if i power my arduino from my computer)...
i hope this clears out the problem i'm having.
i'll also post a picture so i'm extra sure everybody will understand  XD
Grumpy_Mike
Just to get things straight:-
when powered from the USB and connected to your synth it works
when powered from an external supply through the jack and connected to your synth it doesn't work
If that is the case then it is your external power supply that is faulty or in some way not right.
What voltage output is it?
Does it have a DC output or an AC one?
An AC output is wrong and might cause the problems you are seeing.
MarkT
We are concerned that you are driving a lot of outputs and the 12V power supply isn't providing enough current.  I'm also concerned that you might be switching lots of LEDs without enough decoupling, but I'm guessing from some of the comments - I haven't seen the diagram of these output loads.
The USB supply provides 0.5A normally, what is the rating of the 12V supply you are using?
tommyrosa
i'm going to make this as clear as i can, starting from the beginning:
i have made a sequencer using an arduino mega, that outputs 0-3 volts.
the sequencer on it's own works fine powered either from the USB or from an external supply.
obviously a sequencer on it's own isn't very useful, and so i connect it to my synth.
here's where the problems begin: when i power the arduino sequencer from USB, the synth and the sequencer both work fine. :)
instead when i power the arduino sequencer from an external output, the SYNTH starts behaving in a strange way (leds flickering, parameter values changing...), while instead the arduino sequencer itself looks fine and does what it's supposed to do.
i know for sure that the problem lies in my project because as soon as i disconnect the sequencer from the synth, the synth stops acting weird, and if i connect the sequencer back to the synth, the problems start again.
input: AC100-240V   50/60Hz   180mA
output: DC 12V   330mA
i hope this clears things up.
and thanks for helping anyways  XD
MarkT
So its possible that 330mA is not enough?
tommyrosa
no probably not.
i just found out that when i power the arduino sequencer using usb from my pc, if the computer is charging (attached to an external power supply) the synth starts going crazy, the same way it would if the arduino itself were powered from an external power supply.
simply disconnecting the laptop from it's external source solves the issue.
i seriously have no idea of why it behaves like this
Grumpy_Mike
Yes it is totally possible.
Try a power supply with at least a 500mA capacity.
tommyrosa
well ok, as soon as i can i'll give it a try
iyahdub
Sounds like its deffo the Power adapter not having 'nuff juice.
As USB ports deliver between 500mA and 900mA(depending on the version) you'd need a power adapter that conforms within those values.As you seems to be drawing a lot out of it with leds and all, go for the top values given !!
10 LET Loop=Infinite
20 GO TO 10
KVron
no probably not.
You might have some (input) pins floating (not connected or grounded). Check all your connections carefully, it seems that an input is acting like an antenna.
