Topic: Servo position value, can it be real number? (Read 926 times) previous topic - next topic
MilanV
As the topic says, can a value of a Servo position be a real number like 43.5 and not integer??
Code: [Select]
myservo.write(43.5);
I didn't know where to post this question, whether here or at "motors" part of the arduino forum. Thanks!
AWOL
No.
A floating point argument will simply be truncated.
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
AWOL
If you need finer control, you can use the writeMicroseconds method.
However, asking for fractional degree accuracy of an R/C servo may be asking a bit much.
robtillaart
Quote
You might add 0.5 to get proper rounding
float angle = 43.4;
myservo.write(angle + 0.5);  ==> 43 degrees
float angle = 43.6;
myservo.write(angle + 0.5);  ==> 44 degrees
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
