Topic: Yayyyyyyy (Read 3835 times) previous topic - next topic
cjdelphi
http://myarduino.info
I decided to take the plunge and spending a whopping $2.95 (Sale on for .info domains right now ) for a .info domain and point it at my little Arduino :)
http://www.dynonames.com/
nickgammon
So the lights are off, I gather?
More info:
Steen
great job :) nice to see this working. how does it see if the lights are off? since that's quite strange i think ö
cjdelphi
lol it's a cree 3 watt LED (with a power transistor, it does a nice job, but not quite as bright as your 11 watt fluro, but it's close enough), i use +/- from a spare USB port (if the PSU dies or power goes out) that will show 240volts off.
since my PSU is on 24/7, (even when the computer's "off" power still goes out to the arduino and the rest of the attached USB devices.)
- So yeah not much (yet) going on so I thought i'd give it it's own URL :)
Steen
could you post the code? i'm interested in how you set up the html formatting :)
nickgammon
And make a button that beeps if we press it. Then you'll know how many people are reading your post. ;)
More info:
cjdelphi
that's the setup (the computer next to it and router, kinda handy lol)
There's an Arduino Duemonova (can't spell it, i'm not Italian) at the front of the table, and at the back is an Etherten unit.
http://www.freetronics.com/collections/all-products/products/etherten
Works identical to the ethernet shield, same wiznet, same pins used etc.
cjdelphi
#include <Wire.h>
//#include <Adafruit_BMP085.h>
#include <String.h>
#include <SPI.h>
#include <Ethernet.h>
#include <SoftwareSerial.h>
#include <utility/w5100.h>
#define SBLEDPin 8
#define ComputerPowerPin 9
#define USBPowerPin 5
// The IP address will be dependent on your local network:
byte mac[] = {  0x0C, 0x00, 0x0C, 0xE, 0xA, 0xB };
byte ip[] = { 192,168,1, 253 };
byte gateway[] = { 192, 168, 1, 254 }; // internet access via router
byte subnet[] = { 255, 255, 255, 0 }; //subnet mask
byte thismsg;
boolean gotAMessage = false;
EthernetServer server(80);
SoftwareSerial mySerial(6, 7);
//Adafruit_BMP085 bmp;
float p,oldp;
long days=0;
long hours=0;
long mins=0;
long secs=0;
long currentmillis=0;
int visitors = 0;
int sensorvalue;
boolean ledon;
boolean Dimmer;
boolean override;
//  bmp.begin();
  Ethernet.gatewayIP();
  server.begin(); //,gateway,subnet);
  override=false;
  server.begin();
  mySerial.begin(9600);
//  pinMode(ledPinB, OUTPUT);
//  pinMode(ledPinG, OUTPUT);
//  pinMode(ledPinR, OUTPUT);
//  pinMode(SpeakerPin, OUTPUT);
pinMode(SBLEDPin, OUTPUT);
pinMode(ComputerPowerPin, OUTPUT);
  pinMode(USBPowerPin, INPUT);
  char c;
  int buttonState;
  currentmillis= millis();
  secs = currentmillis/1000; //convect milliseconds to seconds
  mins=secs/60; //convert seconds to minutes
  hours=mins/60; //convert minutes to hours
  days=hours/24; //convert hours to days
  secs=secs-(mins*60); //subtract the coverted seconds to minutes in order to display 59 secs max
  mins=mins-(hours*60); //subtract the coverted minutes to hours in order to display 59 minutes max
  hours=hours-(days*24); //subtract the coverted hours to days in order to display 23 hours max
  //Display results
buttonState = digitalRead(USBPowerPin);
if (buttonState == LOW) {
   delay(1);
   if ((override==false) && (ledon==false))
      digitalWrite(SBLEDPin, HIGH);
      ledon=true;
//   sensorvalue = analogRead(sensorpin);
//Serial.print("Sensor Voltage Reading: ");
//    Serial.println(sensorvalue,DEC);
//    delay(150);
  //if (pressure!=0) delay(1);
  // when the client sends the first byte, say hello:
  if (client)
    if (!gotAMessage)
        char crrip[16];
        byte rip[4];
        int bcount;
        //client.
        visitors++;
        client.getRemoteIP(rip); // where rip is defined as byte rip[] = {0,0,0,0 };
        sprintf(crrip, "%d.%d.%d.%d", (unsigned char)rip[0], (unsigned char)rip[1], (unsigned char)rip[2], (unsigned char)rip[3]);
    //    client.getRemoteIPAddress(rip);
//        client.write('a',1);
        //    char c = client.read();
        client.println();
        client.print("Welcome ");
        client.println(crrip);
        client.println("<br>");
        client.println("Hello from my <u><b><i>Arduino!</u></b></i><br>");
        client.print("Main Power: ");
          client.println("<B><I>Main 240 volts OFF</B></I><BR>");
         if (buttonState == HIGH)
           client.println("Main 240 volts OK<BR>");
          client.println("Bedroom Lighting: <B><I>");
          if (ledon==true)
            client.println("ON!");
            client.println("OFF!");
         client.println("</B></I><BR>");
        client.println("Local IP: http://192.168.1.253:1234/WAN IP: http://110.175.97.110:1234 <br>");
        client.print("Hello Visitor Number: <b>");
        client.println(visitors);
        oldp = p;
     if (days>0) // days will displayed only if value is greater than zero
       client.print(days);
       client.print(" days and :");
      client.print(hours);
     client.print("h:");
     client.print(mins);
     client.print("m:");
     client.print(secs);
     client.print("s<br> <BR><BR> - Written By Craig C. (2012)");
        //   if (c=='Q') client.stop();
  //      delay(250);
        client.flush();
        client.stop();
  //      delay(150);
        //   CheckChar(c);
  if (mySerial.available())
    c = (char)mySerial.read();
//    mySerial.print(c);
    CheckChar(c);
    if (c=='v') {
      mySerial.println("Voltage Status: ");
      if (buttonState == HIGH)  mySerial.println("OK");
      if (buttonState == LOW)  mySerial.println("Power OUT!");
void uptime()
  mySerial.println("Running Time");
  mySerial.println("------------");
    mySerial.print(days);
    mySerial.print(" days and :");
  mySerial.print(hours);
  mySerial.print(":");
  mySerial.print(mins);
  mySerial.println(secs);
//############################################ UPTIME ^^^^  #################################
void ToggleLED() {
// digitalWrite(SBLEDPin,HIGH);
// digitalWrite(SBLEDPin,LOW);
void CheckChar(char c) {
// if (c=='t') mySerial.println(bmp.readTemperature());
// if (c=='b') mySerial.println(bmp.readPressure());
// if (c=='a') mySerial.println(bmp.readAltitude());
if (c=='h') {
    mySerial.println("Help");
    mySerial.println("p = power button (quick) P = Power Button Long");
    mySerial.println("L = Light On l = Light Off");
    mySerial.println("s = LED Light Status");
    mySerial.println("v = Home Voltage Status (on/off) O(Overide)");
    mySerial.println("u = Uptime");
//    mySerial.println("b = barometer pressure t = Temprature a = Altitude");
if (c=='s') {
  mySerial.print("The LED light is: ");
  if (ledon==true)
     mySerial.println("ON");
  if (ledon==false)
     mySerial.println("OFF");
  if (c=='L') {
    ledon=true;
//   int fade;
//  for (fade=1; fade++; fade>=1023);
   // analogWrite(ASBLEDPin,fade);
   // delay(40);
  if (c=='o') {
    mySerial.print("Override Status: ");
    if (override==false)
       override=true;
       ledon=false;
       return;
    if (override==true)
      override=false;
      ledon=true;
      return;
  if (c=='l') {
  //  analogWrite(ASBLEDPin,0);
   ledon=false;
  if (c=='u')
    uptime();
  if (c=='p') {
    digitalWrite(ComputerPowerPin,HIGH);
    delay(50);
    digitalWrite(ComputerPowerPin,LOW);
  if (c=='P') {
    delay(5000);
There's also bluetooth code there to switch the cree LED on/off.
cjdelphi
be nice with me over the code (please :P), i only started learning C++ a few weeks ago :P
Nishant_Sood
Duemilanove (CAN SPELL it and im not Italian  ]:D :P)
"Real Men can Accomplish  Anything"
- skype : nishants5
ਫ਼ਤੇਹ ਕਰੁਂ!
www.winacro.com
Steen
looks good, but there one thing i don't understand, it seems there some indentation-based language in it (no C/C+) because you do
if (statement)
is that specified for the serverpart of the board? looks nice :) i didn't think it was as simple as just printing "Hello from my <u><b><i>Arduino!</u></b></i><br>" xp
can't you use modulus to convert milis to hours/mins/seconds? that's like 10.000 times easier, and it looks cleaner :)
just do this:
Hours = Milliseconds / (1000*60*60)
Minutes = (Milliseconds % (1000*60*60)) / (1000*60)
Seconds = ((Milliseconds % (1000*60*60)) % (1000*60)) / 1000
But i'm not sure modulus works on the arduino, but i think it should..i hope so
cjdelphi
I'm still learning the language myself after coming from a pascal background so i'm coding the way i would in pascal and adjust it.. Ill fine tune the code and clean it up right now im having too much fun :p
cjdelphi
yep a small beep, i might even add a html button so people can buzz me at 5am in the morning.. on second thoughts :P
pluggy
Due  - What bills are.
milan - Italian City
ove - O-V-E
easy........
http://pluggy.is-a-geek.com/index.html
cjdelphi
easy when you're not typing on a phone and can look it up :P
