Topic: Arduino Sets Sail (Read 2454 times) previous topic - next topic
sbright33
Apr 21, 2012, 02:43 pm Last Edit: Apr 21, 2012, 08:10 pm by Coding Badly Reason: 1
I'm going to try living and building projects on a Sailboat this year...
How to choose which hardware to bring?
Coding Badly
#1
Apr 21, 2012, 08:08 pm Last Edit: Apr 21, 2012, 08:10 pm by Coding Badly Reason: 1
Teeny++ 2.0 with pins.  It's small.  It's powerful.  It works well on a breadboard.  It programs like an Arduino.
Jantje
A laptop
Usb A/B cables
Watertight boxes
8)
Do not PM me a question unless you are prepared to pay for consultancy.
a.d
Take some solar panels perhaps, and maybe some data logging components.
robtillaart
You might contact Joost - http://www.janharing.nl/static.php?page=1 - The stories are in Dutch but google translate is your friend here ;)
Joost sailed around the world and had some homebrew hardware with him.
Rob Tillaart
Nishant_Sood
Do take XBee XSC may be or other higher version of it, will definitely have an added advantage to your projects also it will be a necessity may be.
"Real Men can Accomplish  Anything"
- skype : nishants5
ਫ਼ਤੇਹ ਕਰੁਂ!
www.winacro.com
fkeel
batteries, super-capacitors, power management, solar cells & water proofing equipment :-)
http://embodimentlabs.tumblr.com/
http://paulstrohmeier.info/
Valalvax
A bigger boat
What? Someone had to say it!
(to store all the things you might need!)
Ran Talbott
First, you need to ask some questions to define your goals and needs more clearly.
Will you just be living aboard in an urban harbor (where you could mail-order any parts you overlooked)? Or heading off for a long stay on a desert island?
Will you be building gadgets for the boat that will permanently tie up Arduinos and parts (and maybe should use the smaller, DIP-form-factor clones)?  Or will you be doing "educational" projects (which might mean more proto shields so you can leave multiple projects set up and swap Arduinos among them)?
