Topic: Auto-Detect the need for code tags? (Read 1 time) previous topic - next topic
James C4S
Since many new or first time posters come asking about code-related problems, it would be helpful to show them the code-tag feature.  If a post contains the strings "void setup()" and "void loop()" but not any code tags, would it be possible to display a warning before committing the post?  Maybe something similar to the red-message when someone replies while drafting a 2nd reply.
smeezekitty
I would think code would be somewhat hard to detect programmatically but it is certainly possible.
Those functions as well as { } or more then a certain amount of ; could also work since those are all relatively rare in normal text.
Avoid throwing electronics out as you or someone else might need them for parts or use.
Solid state rectifiers are the only REAL rectifiers.
Resistors for LEDS!
el_supremo
It also might help if an icon could be designed which looks more like code. To me, the # symbol doesn't mean "code" at all whereas the icon for quoting text does imply quoting something. First time users might be more likely to use it if was more representative of what it does.
Pete
Don't send me technical questions via Private Message.
James C4S
Maybe a big button that just says:  "Code Tags" would work?
el_supremo
That's a good idea :) Or perhaps the icon could just have "
Pete
smeezekitty
Pete
That didn't work right ;)
Resistors for LEDS!
el_supremo
Oh Geez! :)
What I meant to say was: Or perhaps the icon could just have "[ code ]"
Pete
(I previewed it this time!)
nickgammon
A lot of people don't actually post code that compiles or have them in it. You could have a "does this look like C?" algorithm. Similar to what Google Translate uses to auto-detect languages.
And I agree about the [code] button. (Special trick to make that appear). I made the (empty) gap after the "[" but before the word "code" to be in bold.
More info:
James C4S
I wasn't suggesting a "catch-all" type of approach.  Just a simple "does the string: 'void setup()' exist and '[code]' does not"?  If true, print a simple message and then allow the next post to go through.  Again, similar to what happens when someone posts while you edit/create a post.
Finally!  I could not figure out how you did it.  ;)  Thank you!
