Author Topic: +++ SOLVED +++ More buttons , to show text at lcd or serialprint  (Read 350 times)
Netherlands
Hello all,
I 'am new with the arduino , but the examples in the getting started book is not the problem for me for first of this begin with the arduino,
Now i will do an experiment with more buttons and text ( display at serial or LCD )  , with one button it will works ;-)
But now i will make a sketch with more buttons,
So when i Push button one , the screen display as example button 1 is pressed
And when i push button two , the screen displays as example button 2 is pressed , and further and further,
Now i have make a simple sketch as example with one button (Door contact ) , but i like to make this sketch with more buttons:
 *  Door alarm switch test
#include <Wire.h>
LiquidCrystal_I2C lcd(0x27,16,2);
int switchPin = 2;              // switch is connected to pin 2
int val;                        // variable for reading the pin status
int buttonState;                // variable to hold the last button state
  lcd.init();
  lcd.backlight();
    // set up the LCD's number of columns and rows:
  lcd.begin(16, 2);
  pinMode(switchPin, INPUT);    // Set the switch pin as input
  pinMode(13, OUTPUT);
  pinMode(12, OUTPUT);
  Serial.begin(9600);           // Set up serial communication at 9600bps
  buttonState = digitalRead(switchPin);   // read the initial state
void loop(){
      val = digitalRead(switchPin);      // read input value and store it in val
      if (val != buttonState) {          // the button state has changed!
      if (val == LOW) {         // check if the button is NOT pressed
      lcd.clear();
      Serial.println("Door contact 1 Restored "); // put at serial
      lcd.println("  Door contact 1  "); // put text at row 1 lcd
      lcd.setCursor(0, 1); // use row  2
      lcd.print("    Restored  ");// row 2 at lcd
    } else {                         // the button is pressed...
      lcd.clear();
      Serial.println("Door contact 1 Activated ");// at serial
      lcd.println(" Move Detection  ");// row 1 at lcd
      lcd.setCursor(0, 1);//row  2
      lcd.print("** Activated **");//row 2 at lcd
  buttonState = val;                 // save the new state in our variable
This sketch is working correct , for now ,
I hope someone can help me further !!!
 smiley-mr-green
« Last Edit: April 22, 2012, 01:44:02 pm by ArduinoPat » Logged
Patrick ,The Netherlands
Seattle, WA USA
Seattle, WA USA
Unfortunately, that is a pretty lousy example. I prefer variable names that really indicate the value that they hold.
currState = digitalRead(switchPin);
if(currState !=prevState)
prevState = currState;
Now, looking at this, it is easy to modify to deal with 2 or more switches:
currState1 = digitalRead(switchPin1);
if(currState1 !=prevState1)
prevState1 = currState1;
currState2 = digitalRead(switchPin2);
if(currState2 !=prevState2)
prevState2 = currState2;
Netherlands
Thank's for reply PaulS,
But it will not work yet  smiley-mad
With one button it works !!
But when i make this sketch for two buttons it will not work anymore,
look at this sketch :
 *  Alternating switch
#include <Wire.h>
int switchPin2 = 4;                 // switch is connected to pin 4
int prevState;                      // variable for reading the pin status
int prevState2;                     // variable for reading the pin status
int currState;                      // variable to hold the last button state
int currState2;                     // variable to hold the last button state
  lcd.init();
  lcd.backlight();
  lcd.begin(16, 2);
  pinMode(switchPin2, INPUT);    // Set the switch pin as input
  void loop(){
  if(currState !=prevState){
  if(currState == LOW){
  lcd.println("   ");
  lcd.clear();
  if(currState2 !=prevState2){
  if(currState2 == LOW){
  lcd.println("   ");
  lcd.clear();
  else {
  lcd.print(0, 0);
  lcd.print("BUTTON-1=PRESSED    ");
  lcd.print(0, 0);
  lcd.print("BUTTON-2=PRESSED    ");
This will not work , but with one button it works , when i push the button the LCD shows BUTTON-1= PRESSED
When i loss the button the lcd screen is empty , and that is what i will, but then with more buttons ????
This is working :
#include <Wire.h>
  lcd.init();
  lcd.backlight();
  lcd.begin(16, 2);
  void loop(){
  lcd.println("   ");
  lcd.clear();
  else {
  lcd.print(0, 0);
Maby you can give me some information what i have to do ?
Thank's for read this !!
Patrick, The Netherlands.
Seattle, WA USA
Seattle, WA USA
If you open the first of those sketches, and use Tools + Auto format, you will see that you are only dealing with one switch if the other is pressed.
I don't think this meets the requirements you have defined.
You appear to want the two switches to be completely independent.
Netherlands
Hello PaulS,
I will use more buttons to switch over , and shows at the lcd screen at wath kind of  input the switch is ,
can you give me a complete example please ?
Thank's for reading this ,
Patrick
Seattle, WA USA
Seattle, WA USA
You have a complete example for one switch. Simply copy all the code in loop, and paste it after the code currently in loop, and change the names in the pasted code
   // Code to deal with switch one
   // Code to deal with switch two
Do not paste bits of code inside if or else blocks.
Netherlands
Dear PaulS,
It's working , i have make a simple test with 3 Buttons, during pushing one button it will shows at the display
BUTTON-1=PRESSED
BUTTON-2=PRESSED
BUTTON-3=PRESSED
find attached my sketch,
#include <Wire.h>
int switchPin1 = 4;              // switch is connected to pin 4
int switchPin2 = 7;              // switch is connected to pin 7
  lcd.init();
  lcd.backlight();
  lcd.begin(16, 2);
  pinMode(switchPin1, INPUT);    // Set the switch pin as input
  void loop(){
  lcd.println("   ");
  lcd.clear();
  else {
  lcd.print(0, 0);
 currState = digitalRead(switchPin1);
  lcd.println("   ");
  lcd.clear();
  else {
  lcd.print(0, 0);
  currState = digitalRead(switchPin2);
  lcd.println("   ");
  lcd.clear();
  else {
  lcd.print(0, 0);
  lcd.print("BUTTON-3=PRESSED    ");
Find the example at youtube , smiley-money
Many thank's for your explain,
Best regards ,
Patrick , The Netherlands
« Last Edit: April 22, 2012, 01:17:11 pm by ArduinoPat » Logged
