I need to get this project done as soon as possible (it's part of a bigger project for university), so any help is much much appreciated! Everything works with 1 LED as well as 8 LEDs (on a breadboard using 330 ohm resistors), however I would like to use the LED cluster I bought instead of just 1 LED or 8 LEDs. Also, if you have an ideas for increasing the sensitivity of a sound sensor, please let me know
I have the following LED Cluster from Maplin:
http://images.maplin.co.uk/300/pd01b.jpgHow would I go about connecting this LED cluster to the Arduino? (Please bear in mind I am a total newbie in electronics).
int sensorPin = 4;
// Setting the input pin for the sound sensor
int ledPin = 13;
// Setting the output pin for the light emitting diode
int val = 2;
// Variable to store the value coming from the sensor
pinMode(ledPin, OUTPUT);
// Setting ledPin as the output
// Initialising serial communication with computer
void loop(){
val = analogRead(sensorPin);
// Reading the analogue value from the sensor
Serial.println(val);
// Sending the signal to the computer in the form of ASCII digits
if (val > 3) {
// If the signal value received from the sensor is higher than 460
digitalWrite(ledPin, HIGH);
// Then turn the LED on
else {
// Otherwise
digitalWrite(ledPin, LOW);
// Turn the LED off
delay(30);
LED Cluster details:
Specifications (IF=200mA)
Maximum luminous intensity: 23000mcd
Viewing angle: 40°
Typical forward voltage: 9.6V (11.2V)
Peak wavelength: 660nm
Maximum reverse current: 100µA @ VR=18V
Power dissipation: 2.5W max.
DC forward current: 250mA max.
Reverse voltage: 5V max.
Operating temperature range: -5°C to +65°C
As I said before, this is for uni, so I am stressing a lot right now, any help is appreciated
