Loading...
Pages: 1 2 [3]   Go Down
Author Topic: What hardware can drive one long row of 100 LEDs  (Read 1147 times)
0
Offline Offline
Sr. Member
Arduino rocks
View Profile
You're right. The spacing would be a little tricky to work out. The spacing won't be even due the the fact that the center of the black keys are right between the white keys. Printing examples on paper is a great technique though. Instead of trying to do the math, I would just keep increasing/decreasing the spacing until it fit. The goal is to have each LED centered on each key. I would do it in octaves though. From c to b. You don't need to use the 3mm LEDs. You can use the really tinny ones if that is cheaper.
« Last Edit: April 23, 2012, 10:21:21 pm by David82 » Logged
Global Moderator
Boston area, metrowest
Offline Offline
Brattain Member
Available for Design & Build services
View Profile
WWW
The spacing is not difficult, just some math, resulting in this.
I just printed, will cut & try again.
I have wife's piano, and also an Fatar SL-990 electronic keyboard to try the spacing on.
Rats - still a little off, on the high side this time.
« Last Edit: April 23, 2012, 10:39:44 pm by CrossRoads » Logged
Designing & building electrical circuits for over 25 years. Check out the ATMega1284P based Bobuino and other '328P & '1284P creations & offerings at  www.crossroadsfencing.com/BobuinoRev17
0
Offline Offline
Sr. Member
Arduino rocks
View Profile
I see you're starting on G# for some reason. In my particular case, the piano starts off with A and the highest note is C. Since it is clear that not all pianos start off with the same note, it may be best to just stick to the conventional c through b and just make one more octave than the paino would typically have. That would be used to cover any variation in starting and ending keys.
EDIT: doing a little more research, the lowest note on an 88-key piano seems to always be A0 while the highest note seems to always be C8.
Logged
Global Moderator
Offline Offline
Brattain Member
View Profile
WWW
I had it starting on G# and leaving it off the left most board, made sense when I started; spacing wise I think I have a better handle on it now.
Logged
0
Offline Offline
Sr. Member
Arduino rocks
View Profile
Ok. I guess next step would be to get a prototype printed, populate it, see if everything works on a basic electronic level and then see if it can be interfaced with via PC.
Logged
0
Offline Offline
Sr. Member
Arduino rocks
View Profile
I'm ready when you are with anything you need to get this moving along.
Logged
Pages: 1 2 [3]   Go Up
Print
Jump to:
