Topic: Intermittent compiler complaints of 'Point' does not define a type (Read 3510 times) previous topic - next topic
ajofscott
What is perplexing is that the same typedef structures were working earlier before I added more processes to the application.
Point and Command are defined as follows:
Code: [Select]
typedef struct Point
  int X;
  int Y;
}Point;
typedef struct Command
{ //0 based offsets:
word Verb; //Zero and First  Bytes of Serial stream.
Point Begin; //third to sixthth Bytes (x) Eighth to Eleventh Bytes (y) of Serial stream.
Point Finish; //thirteenth to sixteenth Bytes (x) Eighteeenth to Twenty-first Bytes (y) of Serial stream.
Point AC; //Twenty-third to Twenty-sixth Bytes (x) Twenty-eighth to Thirty-first Bytes (y) of Serial Stream.
unsigned int BA; //Thirty-third to Thirty-sixth Bytes of Serial stream.
unsigned int EA; //Thirty-eighth to Fourty-first Bytes of Serial stream.
unsigned int TD; //Fourty-third to Fourty-sixth Bytes of Serial stream.
              boolean Bias; //Fourty-eighth byte of Serial stream.
              float Scalor; //Scaling factor for motor movement.
              boolean Major; //If true X has the major displacement.
}Command;
Also to add to the puzzlement is that 'Command' is being accepted as a datatype and if a library is included I have to have the inclusion appear after the typedefs or neither one sets.
PeterH
What do you mean by 'intermittent'? The same sketch sometimes compiles OK and sometimes fails?
What do you mean by 'added more processes to the application'?
All I can guess so far is that you are using a library that declares Point as something else.
I only provide help via the forum - please do not contact me for private consultancy.
Nick Gammon
Provide a "working" sketch that demonstrates the problem. Trying to fix compiler errors when you just talk about what you did is not very easy.
Quote
... working earlier before I added more processes ...
Can you elaborate on how you added processes?
Please post technical questions on the forum, not by personal message. Thanks!
More info:
http://www.gammon.com.au/electronics
ajofscott
while trying to format for screen here I became aware of some open grouping symbols.
As far as the intermittent part goes, when I populated the instance ThisCommand, of Type Command directly without calls to GetValueFromString() all was working well, in fact that version is currently running on the UNO. Stupid me I did not make an archival copy before
embellishing on things.
ajofscott
Groupings corrected leaving the only complaint being:
Code too long to post in tags so it is attached.
"tinyComm:-1: error: 'Point' does not name a type
tinyComm.cpp: In function 'void ExecuteMovement()':
tinyComm:158: error: 'GetDisplacements' was not declared in this scope
Nick Gammon
Ah, the IDE has some tricks for you. :)
Make a new tab (button in top RH corner). Call it something.h (eg. definitions.h)
Put the definitions in it, eg.
Code: [Select]
  int X;
  int Y;
}Point;
}Command;
At the start of your main sketch add:
Code: [Select]
#include <Arduino.h>
#include "definitions.h"
Now it almost compiles. You have a couple of other problems, but nothing to do with Point not being defined.
More info:
ajofscott
ajofscott
compiles without errors. Should I always put UDT definitions in a seperate file?
Nick Gammon
Depends a bit on the code, but the IDE rearranges things a bit. What is really happening is that it is "helpfully" generating function prototypes for you. So I bet that the file given to the compiler would start like this:
Code: [Select]
// prototypes
Point GetDisplacements(Point locStart, Point locEnd);
  int X;
  int Y;
}Point;
So it has made a prototype for the function GetDisplacements at the very start, and then throws in your file, which is where Point is declared.
More info:
ajofscott
duly noted, Thanks Nick!
it runs but doesn't work yet
input "MA FF65 AD34 7655 7894*"
gave an output of:
Current X Position = 0
Current Y Position = 0
Awaiting next command.
I must have some error in the way I am branching in ExecuteMovement().
I shall be adding serial print statements to find out where I failed to branch as expected.
ajofscott
Command from the serial terminal
MA 0000 0000 0053 13FF*
pre execute coordinates:
Execute command 'MA':
4D41
post move position:
Current X Position = 83
Current Y Position = 5103
Y is always 16 short, although both X and Y are interpreted from the serial stream with the same algorithm. Any ideas?
Nick Gammon
More info:
ajofscott
Code attached. I have it operating on the mill. I get 0.05 mil/step so an integer is going to be too small but will do fine while I develop the routines.
ajofscott
My servo lib is a modified one such that the step member returns a 1 if a step occours and a 0 if it didn't.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
