Loading...
Pages: 1 [2] 3 4   Go Down
Author Topic: How to create a 38 Khz pulse with arduino using timer or PWM?  (Read 5341 times)
Offline Offline
Newbie
View Profile
Thanks for the explanation. This method it is, then!
Logged
Offline Offline
Newbie
View Profile
I used the following 2 fxn to measure frequency using your (nick gammon's timer method) code.
long getFrequencySampled()
  #define SAMPLES 4096
  long freq = 0;
  for(unsigned int j=0; j<SAMPLES; j++) freq+= 500000/pulseIn(pin, HIGH, 250000);
  return freq / SAMPLES;
long getFrequency()
  long duration=pulseIn(pin, HIGH, 250000);
  Serial.print("duration of pulse is: ");
  Serial.println(duration);  //in microseconds
  duration=duration*2;
  freq = 1000000/duration;
  Serial.print("Frequency is: ");
  Serial.println(freq);
  return freq;
getFrequencySampled() returned a value of 40.5-41 Khz.
getFrequency() returns a value that alternates randomly between 35 Khz and 41 Khz. (for pulse durations of 12 & 14 microseconds)
Any idea why the frequency doesn't equal the theoretical value?
« Last Edit: April 24, 2012, 03:43:57 am by praky » Logged
Global Moderator
Melbourne, Australia
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
My code doesn't use pulseIn. Can you post the whole sketch?
Logged
Offline Offline
Newbie
View Profile
I used pulseIn to measure the freq.
Here is the whole code...
Code:
const int pin = 7;
unsigned long duration;
long x;
long freq;
const byte LED = 10;  // Timer 2 "A" output: OC2A
  pinMode(pin, INPUT);
  pinMode (LED, OUTPUT);
  // set up Timer 2
  TCCR2A = _BV (COM2A0) | _BV(WGM21);  // CTC, toggle OC2A on Compare Match
  TCCR2B = _BV (CS20);   // No prescaler
  OCR2A =  209;          // compare A register value (210 * clock speed)
                         //  = 13.125 nS , so frequency is 1 / (2 * 13.125) = 38095
//  tone (10, 38000);
long getFrequency()
  return freq;
  x=getFrequency();
  Serial.println(x);
  long freq = 0;
Logged
Offline Offline
Newbie
View Profile
Is it possible to create a 38 khz modulated wave by the same method?
Logged
Global Moderator
UK
Offline Offline
Brattain Member
I don't think you connected the grounds, Dave.
View Profile
If you're going to use it for modulated IR, just connect one end of your LED to your constant 38kHz source, and the other end to another output pin.
Waggling the other output pin at your desired (<38kHz!) rate produces a modulated 38kHz IR beam.
Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
Manchester (England England)
Offline Offline
Brattain Member
Solder is electric glue
View Profile
WWW
If you want to modulate the IR then that is what the interrupted service routine was to do in the code I originally posted. It is best to do this since the modulation can be synchronised with the carrier.
Logged
Global Moderator
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
PulseIn isn't particularly accurate. From the documentation:
Quote
The timing of this function has been determined empirically and will probably show errors in longer pulses
I checked the timer output on the oscilloscope. Plus, assuming your clock is accurate, it matches the theory. PulseIn just works by counting in a loop.
It looks like Mike's solution incorporates an ISR to turn the output of the timer on or off, exactly at the start of each pulse, which, as he says, would synchronize with the carrier.
Logged
Global Moderator
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
Code:
void setIrModOutput(){  // sets pin 3 going at the IR modulation rate
  pinMode(3, OUTPUT);
  TCCR2A = _BV(COM2B1) | _BV(WGM21) | _BV(WGM20); // Just enable output on Pin 3 and disable it on Pin 11
  TCCR2B = _BV(WGM22) | _BV(CS22);
  OCR2A = 51; // defines the frequency 51 = 38.4 KHz, 54 = 36.2 KHz, 58 = 34 KHz, 62 = 32 KHz
  OCR2B = 26;  // deines the duty cycle - Half the OCR2A value for 50%
  TCCR2B = TCCR2B & 0b00111000 | 0x2; // select a prescale value of 8:1 of the system clock
He's using a different mode (PWM) and a different prescaler, but you can work out the maths:
Code:
1 / ((1 / 16e6) * 8 * 52) = 38461.538
So, his timer will generate 38.46 KHz, as advertised.
Logged
Offline Offline
Newbie
View Profile
I am a newbie with assembly with avr. can you please post the code of 38 Khz wave modulated with 1 Khz wave to be used with TSOP1738.
Will be a life saver. Thanks.
Logged
Global Moderator
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
What was wrong with Claghorn's suggestion on page 1?
Logged
Offline Offline
Newbie
View Profile
i don't know a lot about modulation and synchronization. I get the idea that grumpy_mike's code with little modification will produce a modulated 38 Khz wave with 1 Khz. Any idea what to modify in that code?
Logged
Dubai, UAE
Offline Offline
Edison Member
View Profile
WWW
   If all you are trying to do is generate a 38khz carrier, switched at 1khz, why not do it in hardware with a single 556 Timer, that what this does -
http://rcarduino.blogspot.com/2012/03/punk-consoles-and-ir-transmitters-555.html
It costs about 2 dollars to build.
Duane B
Logged
Offline Offline
Newbie
View Profile
As I have said before, I really don't want to do that unless I can't do it with software.
I am successful in generating 38 Khz thanks to you guys, now I just need it modulated with 1Khz
Logged
Offline Offline
Newbie
View Profile
@nick
Your code produces output at pin 10 using timer 2. Can't I similarly produce output of 1 KHz using Timer1 at some other pin? Then connect this pin at the other end of led?
Logged
Pages: 1 [2] 3 4   Go Up
Print
Jump to:
