« on: April 21, 2012, 07:09:52 pm » |
Hello, I am trying to do a Reset after the user enters his numbers. I am also trying to fix my while loops because once in the loop it just stays there and if the user tries the other combination it wouldn't allow him because of the while loop. I know the problem is because of the condition I have inside my while loop (i.e the 1) but I don't know what condition to put inside it so when the user start pressing the keys the program will reset the previous input and let the user put the new combination. The program works but I have to reset using the reset button of the arduino. I want some reset in the code. Thank you very very much. Here is my code: #include <Keypad.h> #include <Password.h> int IOXpin =2; Password Disp1 = Password( "20" ); Password Disp2 = Password( "200" );
const byte ROWS = 4; //four rows const byte COLS = 3; //three columns char keys[ROWS][COLS] = { { '1','2','3' } , { '4','5','6' } , { '7','8','9' } , { '*','0','#' } };
byte rowPins[ROWS] = { 5, 4, 3, 12}; //connect to the row pinouts of the keypad byte colPins[COLS] = { 8, 7, 6}; //connect to the column pinouts of the keypad
Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS ); void setup(){ pinMode(IOXpin, OUTPUT); Serial.begin(9600); keypad.addEventListener(keypadEvent); //add an event listener for this keypad }
void loop(){ digitalWrite(IOXpin, HIGH); keypad.getKey(); char key = keypad.getKey(); Serial.println(key); }
//take care of some special events void keypadEvent(KeypadEvent eKey){ switch (keypad.getState()){ case PRESSED: Serial.print("Pressed: "); Serial.println(eKey); switch (eKey){ case '*': checkDisp1(); break; case '#': checkDisp2(); case '1': Disp1.reset(); Disp2.reset(); break; default: Disp1.append(eKey); Disp2.append(eKey); } } }
void checkDisp1(){ if (Disp1.evaluate()){ Serial.println("Dispensing 20 uL"); //Add code to run if it works while(1) { digitalWrite(IOXpin, LOW); delay(100); digitalWrite(IOXpin, HIGH); delay(100); } } else{ Serial.println("Not Available!! Reset using 1"); //add code to run if it did not work digitalWrite(IOXpin, HIGH); } } void checkDisp2(){ if (Disp2.evaluate()){ Serial.println("Dispensing 200 uL"); //Add code to run if it works while(1) { digitalWrite(IOXpin, LOW); delay(1000); digitalWrite(IOXpin, HIGH); delay(1000); } } else{ Serial.println("Not Available!! Reset using 1"); //add code to run if it did not work digitalWrite(IOXpin, HIGH); } }
South Texas
« Reply #1 on: April 21, 2012, 08:05:57 pm » |
Is it time dependent? Use millis() and check for a time out and then reset the values.
Configure it so the user hits some key to start the entry sequence. Like a "command" key
« Reply #2 on: April 22, 2012, 02:07:26 am » |
No it's not time dependent. I just want to sense when the user start touching the keys and that should trigger something to reset the previous entry and leave the loop. Turn pin 2 high and then it's ready to check the new entry.if it's correct it will enter the second loop if not it'll go to the second condition(not available!!) Thanks
Seattle, WA USA
Seattle, WA USA
« Reply #3 on: April 22, 2012, 06:42:37 am » |
keypad.getKey(); char key = keypad.getKey(); Serial.println(key); Read the keypad, and throw the value away. Read it again, and print the key being pressed, even if no key is being pressed. Why? while(1) { digitalWrite(IOXpin, LOW); delay(100); digitalWrite(IOXpin, HIGH); delay(100); } If this statement is ever reached, the infinite loop is the only thing that the code will ever do. Not the greatest idea to not include a way to get out of this loop. Fortunately, the Arduino people did provide a way - the reset button.
« Reply #4 on: April 22, 2012, 09:36:54 pm » |
I appreciate the response, but what you trying to say with you answer. I have a problem with loop how can we solve it?
California
« Reply #5 on: April 23, 2012, 01:06:22 am » |
Use a variable to determine if we need to blink the LED: int blinkLED = 0; // Global scope Instead of an infinite loop, we can remove the delays: const unsigned long interval = 250; // Global Scope unsigned long lastEdgeTime = 0; // time since last switch int blinkingLEDState = LOW; // Start with low
In our Arduino's loop, we constantly check how long it's been since we turned on/off the LED: if((blinkLED==1)&&(millis() - lastEdgeTime > interval) ) { // check if it's been at least interval time since last switch and we should be blinking it lastEdgeTime = millis(); // reset our interval timer blinkingLEDState = blinkingLEDState==HIGH?LOW:HIGH; // switch from HIGH to LOW or LOW to HIGH digitalWrite(IOXpin, blinkingLEDState); // write to the pin } So what this allows you to do is not use delays and constantly run the loop so that you can check for user input. When the user does something such that you don't need to blink the LED, simple set blinkLED to 0 and turn it off.
« Reply #6 on: April 23, 2012, 01:53:28 pm » |
Thank you very much. I think what you suggested is almost working the only problem is I want to turn on and off IOXpin exactly the amount of time I had on my while loop. Because I am trying to control a pump. This pump has a pin when you apply 5v to it, it stops and when you apply 0V it turns on. Basically, you stop it with turning the IOXpin high. Here is the changes I did to my code. And thanks again for the help. #include <Keypad.h> #include <Password.h> int blinkLED =0; //Global variable to see if we need to turn the
const unsigned long interval = 250; // Global Scope //pin IOX high or not unsigned long lastEdgeTime = 0; // time since last switch int blinkingLEDState = LOW; // Start with low
void loop(){ //digitalWrite(IOXpin, HIGH); keypad.getKey(); }
//take care of some special events void keypadEvent(KeypadEvent eKey){ switch (keypad.getState()){ case PRESSED: Serial.print("Pressed: "); Serial.println(eKey); switch (eKey){ case '*': checkDisp1(); break; case '#': checkDisp2(); case '1': Disp1.reset(); Disp2.reset(); break; default: Disp1.append(eKey); Disp2.append(eKey); Serial.flush(); } } }
// while(1) // { // digitalWrite(IOXpin, LOW); // delay(100); // digitalWrite(IOXpin, HIGH); // delay(5000); // }
else{ Serial.println("Not Available, Reset!!");
// while(1) // { // digitalWrite(IOXpin, LOW); // delay(1000); // digitalWrite(IOXpin, HIGH); // delay(5000); // }
if((blinkLED==1)&&(millis() - lastEdgeTime > interval) ) { // check if it's been at least interval time since last switch and we should be blinking it lastEdgeTime = millis(); // reset our interval timer blinkingLEDState = blinkingLEDState==HIGH;//?LOW:HIGH; // switch from HIGH to LOW or LOW to HIGH digitalWrite(IOXpin, blinkingLEDState); // write to the pin }
} else{ Serial.println("Not Available, Reset!!");
« Reply #7 on: April 23, 2012, 04:24:12 pm » |
Could you, please, provide some feedback on what I am doing wrong. Thanks
« Reply #8 on: April 23, 2012, 11:13:53 pm » |
No answer?
Seattle, WA USA
Seattle, WA USA
« Reply #9 on: April 24, 2012, 04:31:42 am » |
Could you, please, provide some feedback on what I am doing wrong. Could you please describe what that code is doing, and how what it does differs from what you want. With your vague handwaving, it's really hard to tell you how to fix the code.
« Reply #10 on: April 24, 2012, 04:30:50 pm » |
Hi, thank you very much, Forget about the modification I did in the last post. Here is the one I have now: #include <Keypad.h> #include <Password.h> int IOXpin =2; Password Disp1 = Password( "20" ); Password Disp2 = Password( "200" );
Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS ); void setup(){ pinMode(IOXpin, OUTPUT); Serial.begin(9600); // change this to 115200 keypad.addEventListener(keypadEvent); //add an event listener for this keypad }
void loop(){ digitalWrite(IOXpin, HIGH); keypad.getKey(); }
void checkDisp1(){ if (Disp1.evaluate()){ Serial.println("Dispensing 20 uL"); //Add code to run if it works while(Disp2.evaluate() != '200') { digitalWrite(IOXpin, LOW); delay(100); digitalWrite(IOXpin, HIGH); delay(5000); } } else{ Serial.println("Not Available, Reset!"); //add code to run if it did not work digitalWrite(IOXpin, HIGH); } } void checkDisp2(){ if (Disp2.evaluate()){ Serial.println("Dispensing 200 uL"); //Add code to run if it works while(1) { digitalWrite(IOXpin, LOW); delay(1000); digitalWrite(IOXpin, HIGH); delay(5000); } } else{ Serial.println("Not Available, Reset!"); //add code to run if it did not work digitalWrite(IOXpin, HIGH); } }
The code work like how the password code works: /* || Simple Password Entry Using Matrix Keypad || 4/5/2012 Updates Nathan Sobieck: Nathan@Sobisource.com || */
//* is to validate password //# is to reset password attempt
#include <Password.h> //http://www.arduino.cc/playground/uploads/Code/Password.zip #include <Keypad.h> //http://www.arduino.cc/playground/uploads/Code/Keypad.zip
Password password = Password( "1234" );
const byte ROWS = 4; // Four rows const byte COLS = 4; // columns // Define the Keymap char keys[ROWS][COLS] = { {'1','2','3','A'}, {'4','5','6','B'}, {'7','8','9','C'}, {'*','0','#','D'} };
byte rowPins[ROWS] = { 9,8,7,6 };// Connect keypad ROW0, ROW1, ROW2 and ROW3 to these Arduino pins. byte colPins[COLS] = { 5,4,3,2, };// Connect keypad COL0, COL1 and COL2 to these Arduino pins.
// Create the Keypad Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
void setup(){
void loop(){ keypad.getKey(); }
//take care of some special events void keypadEvent(KeypadEvent eKey){ switch (keypad.getState()){ case PRESSED: Serial.print("Pressed: "); Serial.println(eKey); switch (eKey){ case '*': checkPassword(); break; case '#': password.reset(); break; default: password.append(eKey); } } }
void checkPassword(){ if (password.evaluate()){ Serial.println("Success"); //Add code to run if it works }else{ Serial.println("Wrong"); //add code to run if it did not work } } So in my case when the user hits the right combination, I want to display the message "Dispensing whatever 20uL or 200uL" and it will start the loop (Turn a pin high for some time and low for some time in a loop) in my case I am using pin 2. I hope I clarified what I am looking for.
Melbourne, Australia
Shannon Member
Lua rocks!
« Reply #11 on: April 24, 2012, 11:12:21 pm » |
while(1) { digitalWrite(IOXpin, LOW); delay(1000); digitalWrite(IOXpin, HIGH); delay(5000); } Describe in your own words what you think this will do.
« Reply #12 on: April 24, 2012, 11:18:10 pm » |
That loop need some work. I know because I put that "1" inside the while (i.e while(1)) that's why when the user inputs the right combination it just stays in loop because it's always true. But What I want is if the user touched any key from the keypad it will exit the loop, that's simply what I am trying to do. I tried putting inside the () of the while loop something like "key" or ekey thinking that variable stores the current reading but it didn't work. Let me know if you have any help to provide us with. Thanks
Shannon Member
Lua rocks!
« Reply #13 on: April 24, 2012, 11:33:15 pm » |
So when they enter the right password you want it to dispense stuff for ever? I hope you have a lot of this stuff.
« Reply #14 on: April 25, 2012, 01:10:46 am » |
At first the OIX pin will be set high. You can see that in the beginning of my void loop setup. Because that pin stops my micro pump when it's high. So I want it high when you first power the system. Then when the user put the right combination it will go to my two loops, depending on the selection. If the user selected 20 then it will execute the first loop. If the user didn't enter the right combination the pin IOX will stay high to keep the pump in the stop mode. Now if the user entered the right combination, I will print a message (dispensing 20 ul) and the pin start turning high and low (see my time) until the user touches the keys again in which case the IOX pin will turn high to stop the pump again and wait for the next entry, if it's 200 then that's good it'll go to the second loop, if it's 20 it'll go back to the first loop if it's not one of these two the program should exit the loop and turn the pin IOX high again to stop the pump. My problem is just how do you get out of the loop and reset the system, I need a condition (maybe getkey() function to tell me that the user touched the keys or something). Please some sample code, just suggesting things doesn't help me I hope this makes it clear Thank you very much for your time. Thank you.
