Loading...
Pages: 1 [2]   Go Down
Author Topic: How to sync motor speed???  (Read 1102 times)
0
Offline Offline
Jr. Member
Arduino rocks
View Profile
Does it look like this?:
http://www.ebay.com/itm/FAULHABER-DC-12V-Motor-2342L012CR-Gear-64-1-Encoder-12CPR-free-ship-/130585677299
The 12CPR likely indicates it's using a pair of hall sensors and a multipole disk magnet for the encoder.
Which would be 64:1 x 12 CPR = 768 CPR at the shaft. With the gear head that is a pretty good count.
Edit: Just saw the back of the motor, it's slotted disk and opto, not multipole magnetic and hall...
Ya mine is a round pcb on the back not a rectangle one..
« Last Edit: April 10, 2012, 10:50:06 pm by SuperMiguel » Logged
0
Offline Offline
Jr. Member
Arduino rocks
View Profile
few code modification:
Code:
int E1 = 5;     //Right Motor Power
int E2 = 6;     //Left Motor Power
int M1 = 4;    //Right Motor Direction
int M2 = 7;    //Left Motor Direction
const byte encoder0pinA = 2; //Interrupt 0
const byte encoder0pinB = 12;
const byte encoder1pinA = 3; //Interrupt 1
const byte encoder1pinB = 13;
byte overflow;
byte encoder0PinALast;
byte encoder1PinALast;
int duration0;//Encoder0 number of pulses
int duration00;
int duration1;//Encoder1 number of pulses
int duration11;
boolean Direction0;
boolean Direction1;
int SetPoint = 0; // 0 would be straight ahead
double Kp = 25; // needs tunning
int error = 0;
int speed = 100; // set the speed of which the vechicle should move
int output = 0;
  pinMode(4, OUTPUT);
  pinMode(5, OUTPUT);
  pinMode(6, OUTPUT);
  pinMode(7, OUTPUT);
  Serial.begin(9600);//Initialize the serial port
  EncoderInit();//Initialize the module
  timer_init();
//  Serial.print("Left Pulse:");
//  Serial.println(duration00);
//  Serial.print("Right Pulse:");
//  Serial.println(duration11);
  digitalWrite(M1,LOW); //Forward
  digitalWrite(M2,LOW);
  delay(1500);
  digitalWrite(M1,HIGH); //Backwards
  digitalWrite(M2,HIGH);
  delay(1500);
  speed = 0; //STOP!!!!!!
  Kp = 0;
  delay(4000);
  speed = 100;
  Kp = 25;
ISR(TIMER1_OVF_vect)
  overflow++;
  if(overflow>=10)
  Preg(duration0, duration1);
  duration00=duration0;
  duration0=0;
  duration11=duration1;
  duration1=0;
  overflow=0;
void Preg(int SpeedL, int SpeedR)
  noInterrupts(); // Disable interrupts, no need to slow down the P regulator
  error = ((SpeedL-SpeedR)-SetPoint);
  output = (Kp*error);
  if(error >= 0) // its turning left of the setpoint, reduce E1 (right motor)
    analogWrite(E2, speed);
    analogWrite(E1, (speed-output)); // Subtract the error value multiplied by Kp from E1
  if(error < 0) // turning right of our setpoint, reduce E0
    analogWrite(E2, (speed+output)); // This time we add the error since its negative
    analogWrite(E1, speed);
  interrupts(); //Enable interrupts again
void timer_init(void)
  TIMSK1 |= (1<<TOIE1); // Enable Timer1 overflow interrupt at 16MHz = 16 000 000 / 2^16 = 244Hz
void EncoderInit()
  Direction0 = true;
  Direction1 = true;
  pinMode(encoder0pinB,INPUT);
  attachInterrupt(0, wheelSpeed0, CHANGE);
  pinMode(encoder1pinB,INPUT);
  attachInterrupt(1, wheelSpeed1, CHANGE);
void wheelSpeed0()
  //Encoder 0 Code
  int Lstate = digitalRead(encoder0pinA);
  if((encoder0PinALast == LOW) && Lstate==HIGH)
    int val0 = digitalRead(encoder0pinB);
    if(val0 == LOW && Direction0)
      Direction0 = false; //Reverse
    else if(val0 == HIGH && !Direction0)
      Direction0 = true;  //Forward
  encoder0PinALast = Lstate;
  if(!Direction0)  duration0++;
  else  duration0++;
void wheelSpeed1()
  //Encoder 1 Code
  int Lstate1 = digitalRead(encoder1pinA);
  if((encoder1PinALast == LOW) && Lstate1==HIGH)
    int val1 = digitalRead(encoder1pinB);
    if(val1 == LOW && Direction1)
      Direction1 = false; //Reverse
    else if(val1 == HIGH && !Direction1)
      Direction1 = true;  //Forward
  encoder1PinALast = Lstate1;
  if(!Direction1)  duration1++;
  else  duration1++;
Logged
0
Offline Offline
Jr. Member
Arduino rocks
View Profile
Is there a better implementation of this????
Logged
UK
Offline Offline
Tesla Member
View Profile
Is this just a general 'please make my code better' or is there some specific problem you want help with?
Logged
0
Offline Offline
Jr. Member
Arduino rocks
View Profile
Ya is there a lib to help me find kp?? And is my pid implementation correct?? Should I try using the pid lib?? Any benefits??
Logged
0
Offline Offline
Newbie
n0m1 design
View Profile
WWW
Here's a more conventional example:
http://letsmakerobots.com/node/865
Logged
Seattle WA
Offline Offline
Full Member
Arduino rocks
View Profile
WWW
I hadn't seen the LetsMakeRobots article before, but it looks really good. I would try to use a tested library (like the one I linked to earlier), because it will get you to your goal faster.
Logged
0
Offline Offline
Jr. Member
Arduino rocks
View Profile
Cant figure out how to use that library.. Can you give me an example on how i would use it? the examples on that article are no that clear to my problem
Logged
Pages: 1 [2]   Go Up
Print
Jump to:
