Vancouver, WA
« on: April 22, 2012, 01:42:12 pm » |
the code that I'm using looks like this: const int analogPin = A0; const int ledPin = 13; const int threshold = 400;
void setup() { pinMode(ledPin, OUTPUT); Serial.begin(9600); }
void loop() { int analogValue = analogRead(analogPin); if (analogValue > threshold) { digitalWrite(ledPin, HIGH); } else { digitalWrite(ledPin, LOW); } Serial.println (analogValue); } I would like to change it so that it works with multiple LEDs in parallell. I've gotten this far: const int analogPin = A0; const int firstPin = 2; const int secondPin = 3; const int thirdPin = 4; const int fourthPin = 5; const int fifthPin = 6; const int firstthreshold = 205; const int secondthreshold = 410; const int thirdthreshold = 615; const int fourththreshold = 820; const int fifththreshold = 1023;
void setup() { pinMode(firstPin, OUTPUT); pinMode(secondPin, OUTPUT); pinMode(thirdPin, OUTPUT); pinMode(fourthPin, OUTPUT); pinMode(fifthPin, OUTPUT); Serial.begin(9600); }
int analogValue = analogRead( And I can't figure out how to get passed that analogRead() event. Any and all help will be helpful. Thanks!
-skeeter_mcbee-
Now, More Than Ever
« Reply #1 on: April 22, 2012, 02:05:57 pm » |
I can't figure out how to get passed that analogRead() event. const int analogPin = A0; ? ? Is that legal in that form? A0 - A5 correspond to 14-20 Should it then be: const int analogPin = 14; ? ?
Don't Be Upset By The Results You Didn't Get With The Work You Didn't Do
Austin, TX
CMiYC
« Reply #2 on: April 22, 2012, 02:07:38 pm » |
You'll have to explain a little bit more about what you want to do. What are the conditions you want to define for each of those LEDs? const int analogPin = A0; Is that legal in that form? A0 - A5 correspond to 14-20 Should it then be: const int analogPin = 14; Yes, that's legal syntax. There is no difference by using "A0" or "14". So I don't understand what you are questioning.
UK
Online
« Reply #3 on: April 22, 2012, 02:08:01 pm » |
@runawaypancak, A0 is 14. What point are you trying to make?
Now, More Than Ever
« Reply #4 on: April 22, 2012, 02:13:13 pm » |
That the analogPin value is then an integer "A0"? In past I just use analogValue = analogRead(A0); Does the IDE differentiate/understand that using "A0" or "14" is all the same?
UK
Online
« Reply #5 on: April 22, 2012, 02:16:33 pm » |
The IDE has nothing to do with it; the preprocessor simply replaces A0 with the literal 14.
Now, More Than Ever
« Reply #6 on: April 22, 2012, 02:21:38 pm » |
OK The 'Arduino Reference' example is: int analogPin = 0; // They actually used [b]3[/b], same concept // They didn't use int analogPin = A3; or int analogPin = A0;
void loop() { val = analogRead(analogPin); // read the input pin Serial.println(val); // debug value }
UK
Online
« Reply #7 on: April 22, 2012, 02:24:55 pm » |
I still don't see what point you are trying to make; in this context (analogRead), zero and fourteen are completely interchangeable.
Now, More Than Ever
« Reply #8 on: April 22, 2012, 02:33:18 pm » |
Well, I'm not trying to make a point or be a pain - I'm trying to get it (too). An integer = 0 and A0? Likewise, an integer = 3 and A3? Just didn't think I've seen analogRead with an alias declared as int = A0 (or Ax) before. Thought that might be what's holding up the analogRead that our friend can't get past.
Well, if the pre-processor figures it all out in context then fine.
Austin, TX
CMiYC
« Reply #9 on: April 22, 2012, 02:35:40 pm » |
Well, if the pre-processor figures it all out in context then fine. It's a combination of the pre-processor (Ax alias) AND the actual function analogRead(). The 'Arduino Reference' example is: int analogPin = 0; // They actually used [b]3[/b], same concept // They didn't use int analogPin = A3; or int analogPin = A0;
Look at the function analogRead(): int analogRead(uint8_t pin) { //... removed for clarity if (pin >= 14) pin -= 14; // allow for channel or pin numbers #endif The very first thing analogRead() does convert values like 14 (for the ATmega328) to 0. So if you pass A0 (which is replaced with 14 by the preprocessor), 14, or 0; analogRead() treats them all the same. Just didn't think I've seen analogRead with an alias declared as int = A0 (or Ax) before.
You might be interested in the section on "Pin Mapping": http://arduino.cc/en/Tutorial/AnalogInputPins
UK
Online
« Reply #10 on: April 22, 2012, 02:38:46 pm » |
RunawayPancake, No, you're still missing the point. The preprocessor has no knowledge of any context of analogRead, it blindly replaces A0 with 14. However, in the particular context of analogRead, zero and fourteen are equivalent. Obviously, in any other context, the equivalence would not hold, you could not, for instance, write "A0 == 0" and expect it to be true.
Now, More Than Ever
« Reply #11 on: April 22, 2012, 02:46:41 pm » |
James C4S, So, it gets sorted - 0/A0/14 associated with analogRead yield the same result. OK.
skeeter_mc, Place a Serial.print or two in your 'sketch' to Debug your situation, to find out where it's getting stuck (if it's getting stuck at the analogRead, as you suggest.)
Austin, TX
CMiYC
« Reply #12 on: April 22, 2012, 02:51:19 pm » |
@AWOL,
If possible, It might be appropriate to split this topic. I think the discussion on what A0 is good to keep, but it might distract the original poster.
UK
« Reply #13 on: April 22, 2012, 08:52:42 pm » |
Are you trying to control five LEDs based on five different thresholds on the single analog input pin? In that case, the cheap and cheerful approach is just to take this code from the original sketch and put five copies in your new sketch: if (analogValue > threshold) { digitalWrite(ledPin, HIGH); } else { digitalWrite(ledPin, LOW); }
In the first copy you replace threshold with firstthreshold and ledPin with firstPin . In the second copy you replace threshold with secondthreshold and ledPin with secondPin. You can probably figure the rest out ... For a more elegent solution you would put your thresholds and LED pin numbers in arrays and put in a loop that applies each threshold.
