Loading...
Pages: [1]   Go Down
Author Topic: Ethernet client only connects once then goes down  (Read 241 times)
Offline Offline
Newbie
View Profile
I am working on a project to connect to a website and read some values but my ethernet shield only connects once then fails.
#include <SPI.h>
#include <Ethernet.h>
// Enter a MAC address for your controller below.
// Newer Ethernet shields have a MAC address printed on a sticker on the shield
byte mac[] = {  0x00, 0xAA, 0xBB, 0xCC, 0xDE, 0x02 };
char serverName[] = "www.bisulco.us";
int x=0;
String s[5];
int y=0;
int control=0;
// Initialize the Ethernet client library
// with the IP address and port of the server
// that you want to connect to (port 80 is default for HTTP):
EthernetClient client;
  // start the serial library:
  // start the Ethernet connection:
  if (Ethernet.begin(mac) == 0) {
    Serial.println("Failed to configure Ethernet using DHCP");
    // no point in carrying on, so do nothing forevermore:
    while(true);
  // give the Ethernet shield a second to initialize:
  Serial.println("connecting...");
  // if you get a connection, report back via serial:
  if (client.connect(serverName, 80)) {
    client.println("GET http://bisulco.us/Site/Current.html HTTP/1.0");
    Serial.println("connected");
    // Make a HTTP request:
    client.println();
  else {
    // kf you didn't get a connection to the server:
    Serial.println("connection failed");
  // if there are incoming bytes available
  // from the server, read them and print them:
  if(control==0){
    if (client.available()) {
     char c = client.read();
         x=x+1;
    Serial.print(c);
    if(x>40){
      s[y]=s[y]+x;
      if(c=='\n'){
        y=y+1;
  // if the server's disconnected, stop the client:
  if (!client.connected()) {
    Serial.println("disconnecting.");
    client.stop();
    control=1;
}else if(control==1){
Serial.print(s[0]);
}else{
     Serial.println("OYUT");
Logged
Pages: [1]   Go Up
Print
Jump to:
