Topic: Arduino and Processing communication (Read 1 time) previous topic - next topic
P390
May 03, 2012, 11:23 pm Last Edit: May 04, 2012, 10:48 pm by P390 Reason: 1
Hello,
Pardon my English I am French student
I have a problem of communication between an arduino UNO rev3 and processecing
I would like know how to do communicate the two
I managed to retrieve a value, I can display it independent but I cannot use it as a variable for a test
Code: [Select]
  text(Power,10,10);  //OK
Power is a String value
Code: [Select]
 void Etat_Arduino(int X,int Y)
  if (Power == "Y")  //Yes or No     the test is always wrong even when the test should be true
  text("OK",X,Y);
  text("ERROR",X,Y);
However, if I declare
Code: [Select]
String Power = "Y";
The program displays "OK"
but I am obliged to declare
Code: [Select]
String Power = "N"; or "";
Could you help me,
where can I find tutorials to explain the communication between Arduino and Processing?
My program must receive the Arduino variables but also be capable of change them
Thank you
Krodal
Have you read this: http://www.arduino.cc/playground/Interfacing/Processing
On this page are examples at section "4. communication":  http://arduino.cc/hu/Tutorial/HomePage
P390
Yes, I read.
it slightly helped me. I can not always run my test
Code: [Select]
String Power = "";
if (Power == "1") //OK => Connect
text();
else // No Connect
text();
void serialEvent (Serial port)
    data = port.readStringUntil('.');
    data = data.substring(0, data.length() - 1);
    index_Power = data.indexOf(",");     //  My arduino send "1"
    Power = data.substring(0, index_Power );
PaulS
That snippet makes it appear that serialEvent() is defined inside the draw() function. That is most certainly NOT allowed.
It is why we don't want you posting snippets. Post ALL of your code.
P390
Code: [Select]
 import processing.serial.*;
 Serial port;
 String data = "";
 String Power = "No Connect !";
 int index_Power = 0;
 int index_Alarme =0;
  background(0,0,0);
  size(600,400);
  port = new Serial(this, "COM11", 57600);
  port.bufferUntil('.');
 void draw()
 Etat_Arduino(Power,112,103); //print : "ERROR !" instead of "OK !"
 fill(46, 209, 2);
 text(Power, 70, 320);   //print : "1"
 void Etat_Arduino(String V,int X,int Y)
 if (V == "1")
 text("OK !",X,Y);
 text("ERROR !",X,Y);
I would also like to change the variable that the program of the arduino send me, for example, it sent me "Power = 1" and I want to "Power = 0" so I sent it 0, and I will add another variables, how can I do for the arduino to receive. and processing sent it?
PaulS
What is sending data to the Processing application?
Code: [Select]
So, what is in data now?
Code: [Select]
Make a substring of all the characters in data, and store in data. How useful is that?
Code: [Select]
Suppose data doesn't contain a ,. What will be the value in index_Power?
Code: [Select]
Does is make sense to always call this function? What is the output if index_Power is -1?
Code: [Select]
What does this comment mean? If you want the function to always print "ERROR!", remove the code that does otherwise.
Quote
Is the Arduino the master, and the Processing application the slave? If so, it doesn't make sense for you to be modifying what the Arduino sent, and telling it it was wrong.
The Processing sketch that you posted is not expecting an input string that contains "Power = 1" or "Power = 1" or any variation that contains the string "Power =". There is nothing in the Processing application that changes the value in Power, except for that code that sets it based on what it receives from the serial port.
You haven't posted the Arduino code at all.
So, it isn't clear how to help you.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
