Topic: arduino with fingerprint (Read 2103 times) previous topic - next topic
mhdkifli
hai. I kifli from Indonesia
I connect the microcontroller with a fingerprint cama-sm20
datasheet
Check connection to the microcontroller needs to send data to a fingerprint xx55 xx50 xx01 xx00 xx00 xxAA xx00 xx00 xx00 xx00 xx00 xx00 xx00 xx00 xx00 xx00 xx00 xx00 xx00 xx00 xx00 xx00 xx50 xx01.
fingerprint will send a response xx55 xx50 xx01 xx04 xxAA xx00 xx00 xx00 xx00 xx00 xx00 xx00 xx00 xx00 xx00 xx00 xx00 xx00 xx00 xx00 xx00 xx00 xx54 xx01
how to send commands from the microcontroller to the fingerprint.
please help
sorry if my english is not good
PaulS
How did you connect the fingerprint scanner to the Arduino?
Use Serial.write() to send an array.
mhdkifli
#2
Apr 24, 2012, 03:45 pm Last Edit: Apr 24, 2012, 03:52 pm by mhdkifli Reason: 1
I connect the serial
I make the program as follows:
#include <NewSoftSerial.h>
byte query[24] = {
 0x55, 0xAA, 0x50, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x50, 0x01};
#define rxPin 2
#define txPin 3
NewSoftSerial fingerprint( rxPin, txPin );
 fingerprint.begin(9600);
byte val;
int i ;
 for (i=0 ; i<24 ; i++){
   fingerprint.print(query) ;
 delay(50);
 while(fingerprint.available()>0){
   val=fingerprint.read();
   Serial.print(val, HEX);
   Serial.print(" ");
 Serial.println("--");
but the fingerprint does not give any reply.
whether serial.print serial.write replaced with?
PaulS
The print() and write() methods do very different things. The write() methods send the data as-is. The print method converts the value to a string to send.
It's not surprising that print()ing to it does not work.
You MUST use write().
CrossRoads
This is not quite right:
needs to be:
fingerprint.print(query [ i ] ) ;
to call out the different bytes. Otherwise I think you only send out query[0] 24 times.
You could loop pins 2/3 back to 0/1 & confirm.
I have not used NewSoftSerial, maybe
fingerprint.write (query [ i ] ) ;
is the correct format also.
mhdkifli
I have replaced
with
    fingerprint.print(query,BYTE) ;
fingerprint does not respond
with
    fingerprint.write(query) ;
why ? =(
CrossRoads
Ok, one last time:
   fingerprint.write ( query [ i ] ) ;  // query [ x ] is what pulls up the 0x55, 0xAA, etc as 'i' goes from 0,1,2,3 ...
mhdkifli
byte query[24] = {
#define rxPin 2
#define txPin 3
byte val;
int i ;
    fingerprint.write(query[i]) ;
    Serial.print(" ");
PaulS
According to the user manual, the baud rate is 115200, not 9600.
You should, initially, send the command in setup(). All loop() does is print any response received.
CrossRoads
Will NewSoftSerial do 115,200? That's fast for software controlled read & writes.
The part needs 3.3V and uses 3.3V interface. Are you running the arduino at 3.3V, or do you have a voltage translator chip?
