تهران
« Reply #30 on: May 21, 2012, 11:43:42 am » |
I suggest using ULN or UDN drivers or for better performance MBI LED driver series.
Boston area, metrowest
« Reply #31 on: May 21, 2012, 06:22:13 pm » |
Lower the resistance on the PNP gate pullups - that should turn the current off better. What are you using now?
UK
« Reply #32 on: May 22, 2012, 04:29:52 am » |
Thanks - my first attempt was 1K, just tried 560R which had a similar result - how low can I go before I break something?
UK
« Reply #33 on: May 22, 2012, 06:54:19 am » |
A quick update... now reduced the pullups down to 220R... things are improving but not there yet... just not sure if I will cause damage if I go too low?
« Reply #34 on: May 22, 2012, 11:27:27 am » |
Post your current schematic, lets review.
UK
« Reply #35 on: May 22, 2012, 03:32:17 pm » |
Hi, here is what I have at the moment....
« Reply #36 on: May 22, 2012, 10:57:28 pm » |
Okay, that Schematic as drawn will not work. You need PNP's wired up like this: http://www.mayothi.com/transistors.html
UK
« Reply #37 on: May 23, 2012, 02:20:44 am » |
Cheers CrossRoads..... is this how it should go?
« Reply #38 on: May 23, 2012, 06:45:38 am » |
Now you're looking good!
UK
« Reply #39 on: May 24, 2012, 04:10:38 am » |
I'm getting there slowly with your help :-) I have also just ordered Electronics for Dummies.....
I have the circuit breadborded out as per the last schematic but with 1K pullup resistors - it all seems to work great with the exception that the shift register IC gets too hot very quickly. Is there anything I can do to solve this?
« Reply #40 on: May 24, 2012, 11:20:23 pm » |
Why is it hot? 12V/1K = 12mA, * 7 worst case = 84mA, shoudn't be hot from that. The TPIC6B595 is powered from 5V?
UK
« Reply #41 on: May 25, 2012, 01:28:15 am » |
Yip, TPIC6B595 is on 5v.
« Reply #42 on: May 25, 2012, 09:12:36 am » |
Try an experiment - with no LEDs on (all outputs high), does it get hot also?
UK
« Reply #43 on: June 13, 2012, 03:57:05 pm » |
Hi there.... well this in now finally working :-)... so here is the circuit to help guide others in a similar position.
Only got joy with the N type MOSSFET, the bit I was missing for a while was a pullup resistor from 12V to Gate.
Thanks for all the help, it is very much appreciated :-)
« Reply #44 on: June 13, 2012, 09:16:26 pm » |
Part # is MOSFET, picture is NPN. Yes, need the pullup to turn the P_channel MOSFET off. 6B595 output going low turns it on.
