Author Topic: expected unqualified-id before numeric constant  (Read 996 times)
Hi there i'm trying to make a project using arduino, Wifly and a GPU screen by vizic technologies, but i'm getting troubles by using TimerOne library, it says i have  expected unqualified-id before numeric constant at the library TimerOne.h here's the code:
#include <Arduino.h>
#include <Streaming.h>
#include <SoftwareSerial.h>
#include "WiFlySerial.h"
#include "MemoryFree.h"
#include "Credentials.h"
#include <SMARTGPU.h>
#include <TimerOne.h>
// Pins are 3 for INCOMING TO Arduino, 5 for OUTGOING TO Wifly
// Arduino       WiFly
//  2 - receive  TX   (Send from Wifly, Receive to Arduino)
//  3 - send     RX   (Send from Arduino, Receive to WiFly)
WiFlySerial WiFly(2,3);
SMARTGPU lcd;
#define REQUEST_BUFFER_SIZE 120
#define HEADER_BUFFER_SIZE 150
#define BODY_BUFFER_SIZE 100
char bufRequest[REQUEST_BUFFER_SIZE];
char bufHeader[HEADER_BUFFER_SIZE];
char bufBody[BODY_BUFFER_SIZE];
int remPort = 3000;
boolean isConn = false;
int touch[2];
int res =0;
boolean Touch = true;
char t[5];
char none[] = {'N','O','N','E','O'};
boolean isNone = true;
int i;
int line = 0, offset = 10, height = 16;
//SETUP
void setup(){
////////////////////////////CONFIG WIFLY/////////////////////////////////
  Timer1.detachInterrupt();
  lcd.init(); //Cnfigura el puerto serial y los pines para el SMARTGPU
  lcd.start(); //Inicializa el SMARTGPU
  printLCD( "GPU OK" );
  WiFly.begin();
  printLCD( "Configuring WiFly..." );
  WiFly.setAuthMode( WIFLY_AUTH_OPEN );
  WiFly.setJoinMode( WIFLY_JOIN_AUTO );
  WiFly.setDHCPMode( WIFLY_DHCP_ON );
  WiFly.setSSID( ssid );
  WiFly.SendCommand("set comm remote h",">", bufBody, BODY_BUFFER_SIZE);
  WiFly.SendCommand("set ip host 10.25.74.172",">", bufBody, BODY_BUFFER_SIZE);
  WiFly.SendCommand("set sys autoconn 2",">", bufBody, BODY_BUFFER_SIZE);
  WiFly.SendCommand("set ip flags 0x6",">", bufBody, BODY_BUFFER_SIZE);
  WiFly.setRemotePort(remPort);
  // If not joined restart link
  printLCD( "Checking WiFly status..." );
  WiFly.getDeviceStatus();
  if (!WiFly.isifUp() ) {
    printLCD( "WiFly if is not up. Joining..." );
    if ( WiFly.join() ) {
      printLCD( "WiFly joined." );
      //WiFly.setNTP( ntp_server ); // use your favorite NTP server
      printLCD( "WiFly join FAIL." );
  } // if not connected
  printLCD( "WiFly OK" );
  printLCD( WiFly.getIP(bufRequest, REQUEST_BUFFER_SIZE));
  printLCD( "Opening TCP connection...");
  WiFly.SendCommand("close",">", bufBody, BODY_BUFFER_SIZE);
  memset (bufBody,'\0',BODY_BUFFER_SIZE);
  delay(3000);
  lcd.erase();
void printLCD( char* text ) {
  lcd.string( offset, nextLine(), 320-offset, 240-offset, WHITE, FONT3, TRANS, text );
int nextLine() {
  if( (line+1)*height > 240-offset ) {
    line = 0;
    lcd.erase();
  return offset + (line++)*height;
/// METODOS PARA LOS DIFERENTES CASOS////
void DISPLAY(){
  lcd.erase();
  WiFly.write('L');
void TOUCH(){
  Timer1.initialize(1000000);
  Timer1.attachInterrupt( ISR_PollWiFly );
  while(true) {
    while(lcd.touchScreen(touch)==0);
      for( i = 0 ; i < 5; i++) {
        WiFly.write(t[i]); //Manda las coordenadas
      DISPLAY();
  WiFly.write('S');
void WriteGPU(){
  char g;
  g = WiFly.read();
  Serial.print(g);
void dibujarFondo() {
  lcd.imageSD(0,0,"TEC");
  lcd.string(30,10,310,220,CYAN,FONT3,TRANS,"Centro de Desarrollo Estudiantil");
  lcd.string(80,30,310,220,CYAN,FONT3,TRANS,"Ofertas de trabajo");
  lcd.drawRectangle(10,50,310,100,WHITE,FILL);
  lcd.drawRectangle(10,110,310,160,CYAN,FILL);
  lcd.drawRectangle(10,170,310,220,0xF805,FILL);
void ISR_PollWiFly(){
  char c;
  while(WiFly.available()) {
     c = WiFly.read();
     if(c == 's') {
       DISPLAY();
//////////////////////////////////////  MAIN  //////////////////////////////////////
void loop(){
  lcd.baudChange(2000000);
  char c;
  c = WiFly.read();
  switch(c){
    case 'q':
      DISPLAY();
    break;
    case 't':
      TOUCH();
    break;
    case 'g':
      WriteGPU();
    break;
    case 'f':
      dibujarFondo();
    break;
    default:
    break;
Dallas
Shannon Member
Comment-out the include...
// #include <TimerOne.h>
Does the error go away?  Move to another place?
It stands the same kind of erros:
Bolsa_T:8: error: expected unqualified-id before numeric constant
Bolsa_T:99: error: expected unqualified-id before numeric constant
Bolsa_T.cpp: In function 'void TOUCH()':
Bolsa_T:113: error: '1' cannot be used as a function
Bolsa_T.cpp: In function 'void ISR_PollWiFly()':
Bolsa_T:140: error: '1' cannot be used as a function
Bolsa_T.cpp: In function 'void loop()':
Bolsa_T:155: error: '1' cannot be used as a function
Dallas
Shannon Member
Put the include back the way it was...
Verify.
Use Ctrl+A to select all the text in the status window.
Use Ctrl+C to copy all the selected text in the status window.
Click Reply.
Paste.
Click Post.
Bolsa_T:9: error: expected unqualified-id before numeric constant
Bolsa_T:100: error: expected unqualified-id before numeric constant
Dallas
Shannon Member
Generally, all uppercase letters are used to define constants.  Which means that using all uppercase letters for function names is a bad idea.  Try using something besides "DISPLAY"...
void DISPLAY(){
  lcd.erase();
  WiFly.write('L');
Thanks a lot!
