Topic: E GOAL! (Read 694 times) previous topic - next topic
Dewalt
Apr 24, 2012, 07:10 pm Last Edit: Apr 25, 2012, 01:42 pm by Dewalt Reason: 1
I need to programm arduino and read signal from four straungauge base sensors sample @ 10 KHZ. About 5-6 mS between mesurements.
Topic: The aim is to make a goal that can measure the speed and accuracy of a ball landing on it. A suggestion of implementation is to make straingauge based sensors and interface them to an Arduino board.
I have Arduino Uno, it is possible to sample at this high freq right?
How can I transfer mesurments to EXEL or MATLAB?
Can u please help me?
robtillaart
Quote
s sample @ 10 KHZ. About 5 mS between mesurements
how do you do that?  10.000 measurements with 5 ms in between makes at least 50 seconds in my math, or did I miss something?
Quote
An Arduino can sample at 7-8 Khz if you use analogRead(), should be enough to get started.
you can get higher sampling speeds - http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1208715493/11 -
Quote
You can send the values to any PC over a serial port. Capture the data with a terminal like putty.exe
This code should get your started
Code: [Select]
unsigned long lastTime = 0;
  while (micros() -100 < lastTime);
  lastTime = micros();
  unsigned long value = analogRead(A0);  // to be replaced by fast analogRead
  Serial.write(value);
Quote
just did, now it is your turn to make the next step.
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
Dewalt
Thanks a lot, I was pretty lost today! Hope I have now something to start with!
