Loading...
Pages: 1 [2]   Go Down
Author Topic: Reading button instantly  (Read 811 times)
Central Wisconsin
Offline Offline
Newbie
View Profile
Code:
return(RightStrip.Color(r,g,b));
  return(LeftStrip.Color(r,g,b));
Hmm
Logged
Global Moderator
UK
Offline Offline
Brattain Member
I don't think you connected the grounds, Dave.
View Profile
Quote
That's exactly what I thought too.
Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
Central Wisconsin
Offline Offline
Newbie
View Profile
I am not very familiar with that.
Familiar with what? EEPROM? It's not complicated at all and there are examples you can look at that will explain it.
See i am a total noob, i understand the concept of what you are trying to say, i just am terrible at programming. i tried looking at the examples but i still do not understand.
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Look at your Wheel() function. What happens when the first return statement is executed? How many values can you return from a function (using the return statement)?
Logged
Central Wisconsin
Offline Offline
Newbie
View Profile
im sorry, i have no idea what you are talking about
Logged
Global Moderator
UK
Offline Offline
Brattain Member
View Profile
Quote
You have a function in the code you posted called "Wheel". Look at it.
Quote
At the end of the function you are looking at are two statements containing the word "return".
What happens when your sketch executes the first of those "return"s?
Why doesn't it matter if there is or isn't a second "return"?
Logged
Central Wisconsin
Offline Offline
Newbie
View Profile
I have two different LED strips hooked up to the arduino, the left one and right one. does that awnser it?
Logged
California
Offline Offline
Edison Member
View Profile
If the examples that they provide are too difficult to understand to you, then there is nothing I could do to help short of writing the code for you.
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Quote
No. The return keyword says "stop executing code at this point, and return this value to the caller". The function can have multiple return statements, but that only makes sense if one of them is in a conditional block, like so:
Code:
int dumb(int a, int b)
   if(a < b)
      return -1;
      return +1;
Code like:
Code:
   // Do some stuff
   return -1;
   return +1;
doesn't make sense, but, that is what you have. The function is supposed to return a value, or it is declared wrong. Two unconditional returns don't make sense.
Logged
Central Wisconsin
Offline Offline
Newbie
View Profile
I took one of the Return() functions out and it seems to work the same.
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Quote
Does that surprise you? The other one was never being executed, anyway. Removing it should have had no impact.
Logged
Central Wisconsin
Offline Offline
Newbie
View Profile
lol, it makes sense now, but back to my real problem. is there an easy way for the push-button to be read consistently, even while the other cycles are running. and be able to stop them mid cycle and switch
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Quote
Sure. Rewrite the code, first, so it does not use delay(). Then, it will be trivial to read the switch and react nearly instantaneously.
If you are having difficulty getting rid of the delay calls, think about how YOU would diddle with the LEDs, given some switches, a watch, and a pad of paper. The switches are the digital pins, the watch is the millis() function, and the pad of paper are the Arduino variables.
Logged
Pages: 1 [2]   Go Up
Print
Jump to:
