Topic: PING sensor giving incorrect values on Pin A0! (Read 5065 times) previous topic - next topic
shailly
Apr 24, 2012, 07:32 pm Last Edit: Apr 24, 2012, 07:38 pm by shailly Reason: 1
I have connected PING sensor to arduino mega 2560 adk
I have connected the SIG pin to analog pin A0
I am getting readings.
but the readings are in a specific range 300-500..
when i try bringing objects in front of the sensor,the values do not change much.
The values are not exact.
This is my code:
const int analogInPin = A0;  // Analog input pin that the potentiometer is attached to
const int analogOutPin = 9; // Analog output pin that the LED is attached to
int sensorValue = 0;        // value read from the pot
int outputValue = 0;        // value output to the PWM (analog out)
 // initialize serial communications at 9600 bps:
 // read the analog in value:
 sensorValue = analogRead(analogInPin);
 // map it to the range of the analog out:
 outputValue = map(sensorValue, 0, 1023, 0, 255);
 // change the analog out value:
 analogWrite(analogOutPin, outputValue);
 // print the results to the serial monitor:
 Serial.print("sensor = " );
 Serial.print(sensorValue);
 Serial.print("\t output = ");
 Serial.println(outputValue);
//convert to cm
long dist=sensorValue*(0.03434);
Serial.print(dist);
 // wait 10 milliseconds before the next loop
 // for the analog-to-digital converter to settle
 // after the last reading:
 delay(10);
The ultrasonic waves of the sensor do not detect objects in front of it or maybe the waves get past through the objects,,Plz help.. Thanks in advance :)
How can i get exact readings in cms../?
The ouput in the serial monitor is like this
15sensor = 510    output = 127
17sensor = 464    output = 115
15sensor = 501    output = 124
17sensor = 477    output = 118
16sensor = 486    output = 121
16sensor = 493    output = 122
16sensor = 470    output = 117
16sensor = 506    output = 126
17sensor = 460    output = 114
15sensor = 513    output = 127
17sensor = 459    output = 114
15sensor = 506    output = 126
17sensor = 469    output = 116
16sensor = 485    output = 120
16sensor = 477    output = 118
16sensor = 500    output = 124
15sensor = 509    output = 126
17sensor = 458    output = 114
15sensor = 500    output = 124
16sensor = 492    output = 122
16sensor = 469    output = 116
15sensor = 512    output = 127
15sensor = 505    output = 125
16sensor = 501    output = 124
Mostly the values are same evn if i move objects in frnt of the sensor
robtillaart
please use the # button to apply proper code tags - you can even modify your existing post.
Read this tutorial? - http://arduino.cc/en/Tutorial/Ping?from=Tutorial.UltrasoundSensor - it provides all the answers (for this q.)
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
shailly
In this tutorial ,the sensor is connected to digital pin 7 and mine is connected to analog pin A0.
n we cant convert the ADC values to cms in the same manner as the tutorial does.
i dont understand why isnt there a major difference in the values when i move objects in front of the sensor.
Is it a delay problem? How much delay one should keep.?
robtillaart
Do you have a link to the datasheet you used? please post the link.
- does the sensor give an analog voltage or a digital pulse (like in the tutorial).
The pulses may look to the analogIn as a medium voltage. That could explain the behavior...
Rob Tillaart
shailly
Heya..thanks for replying. here is the link to the datasheet:
http://www.parallax.com/dl/docs/prod/acc/28015-PING-v1.3.pdf
shailly
The reason why m i using the PING sensor with Analog pin A0,is that the wire is getting loose on the digital pins. PING sensor is mostly used with the digital pins.
the holes of the digital pins on the arduino mega are slightly bigger than the analog pins.
The wire do not fit in the digital pin.Wht should i do? plz help..
=( But i have seen sketches which use PING sensor  with analog pin A0. i just want the values in cms n accurate
AWOL
#6
Apr 25, 2012, 02:09 pm Last Edit: Apr 25, 2012, 02:21 pm by AWOL Reason: 1
Quote
The device has three pins, none of which is an analogue output.
Just use A0 as the Ping pin for the pinMode, digitalWrite etc in the example code.
Please go back to your original post, click on "modify", highlight the code, then click on the # icon on the editor's toolbar, then click on "save". Thank you.
(Not compiled, not tested)
Code: [Select]
const int pingPin = A0;
  long rawRange = pingRange (pingPin);
  long cm = microsecondsToCentimeters(rawRange);
  Serial.print(cm);
  Serial.println("cm");
  delay(100);
long pingRange (int pingPin)
  pinMode(pingPin, OUTPUT);
  digitalWrite(pingPin, LOW);
  delayMicroseconds(2);
  digitalWrite(pingPin, HIGH);
  delayMicroseconds(5);
  // The same pin is used to read the signal from the PING))): a HIGH
  // pulse whose duration is the time (in microseconds) from the sending
  // of the ping to the reception of its echo off of an object.
  pinMode(pingPin, INPUT);
  return pulseIn(pingPin, HIGH);
long microsecondsToCentimeters(long microseconds)
  // The speed of sound is 340 m/s or 29 microseconds per centimeter.
  // The ping travels out and back, so to find the distance of the
  // object we take half of the distance travelled.
  return microseconds / 29 / 2;
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
I speak for myself, not Arduino.
shailly
Hi  AWOL, Thank you so much for the code
The output is still 0 cm..
I think my sensor is faulty
sometimes when i hold the wire tight,it gives out values like 245 cm like tht
but these values r due to electric noise..
How to chekc whether my PING Sensor is faulty or not? The ACT LED on the sensor does not blink.
It hasnt blinked evn once frm the day of purchase.
But i have been gettin values if i hold the wire a little tight when it gets loose.
Plz help me out..Is the sensor faulty?
AWOL
Sorry, I can't really help - I've never even seem a Ping.
Grumpy_Mike
Quote
Trying to do electronics like thesis stupid. You must use the proper connectors and solder wires. Otherwise you can never know if you have a proper connection.
corb
I have tested the code posted by AWOL with a Ping Sensor on A0 on a MEGA 2560 and the setup works perfectly.
There is no difference in the header pins for the Mega 2560, so there is no reason to use Analog pins vs Digital for this, but it will work on A0.
Using standard jumper cables you should get quite a snug fit.
Run a wire from the pin marked GND into Arduino pin marked GND
Run a wire from  the pin marked 5V into Arduiono pin marked 5V
Run a wire from  the pin marked SIG into Arduino pin marked A0
Run AWOL's code or the standard ping lib code modified to use A0.
You should see a bright green LED on the Ping blink like mad and the serial monitor will show correct distance.
