Topic: Using COM-08653 (12 Button Keypad) as simple buttons on microcontroller (Read 4036 times) previous topic - next topic
teamhydraucd
The microcontroller I'm using is the Ethernet Pro Microcontroller (similar to Arduino Uno)
I have this 12 button keypad on the way. The picture below is which buttons are assigned to which key..
My questions are....
1. Are 10 kohm resistors needed to be connected between EACH of the connections to the powersupply?
2. Can this "button" tutorial (http://www.arduino.cc/en/Tutorial/Button) apply with this keypad?
3. After stating each of the 7 pins as INPUT's, will I have a problem pressing multiple buttons at the same time since certain buttons account for the same pin? (ex. "1", "2", "3" share pin 2)
If so, can using the Boolean argument && designation specific buttons?
Nick Gammon
I seem to recall a suggested amendment to the keypad library to allow for multiple button presses. Can't remember offhand where it was, but somewhere in the forum.
See:
http://arduino.cc/playground/Code/Keypad
http://arduino.cc/playground/Main/KeypadTutorial
Please post technical questions on the forum, not by personal message. Thanks!
More info:
http://www.gammon.com.au/electronics
Nick Gammon
More info:
teamhydraucd
Thanks.
I also saw someone suggesting to simply set the pins as inputs and just use the key pad similar to the "button" tutorial.
http://forum.bildr.org/viewtopic.php?t=388
Code: [Select]
    void setup(void)
      pinMode(12, INPUT);
      digitalWrite(12, HIGH);
    void loop(void)
      if (digitalRead(12) == LOW)
        // Do something
        // well then do something else
Is this something I cannot do with this keypad?
In short, I want to use this and input commands to my microcontroller.
Nick Gammon
You have a matrix. Use the matrix library. The keypad one. If you make them inputs you won't read anything. A column has to be output and a row input. Then it pulses each column and tests each row. That's how the matrix works.
More info:
teamhydraucd
Okay. Read through the examples and thought up of a situation I may run into. In my loop, after I defined my keys (as shown in the tutorial), if I decided to consider using "if" statements, and my approach is to say "if, at a point in time, I press and hold '4' on the keypad, then the if statement will follow through in my loop"
for example:
Code: [Select]
char key = kpd.getKey();
    if(key == '4')
      // My specific command
Would this theoretically work until I release the '4' key?
liudr
Serial LCD keypad panel,phi_prompt user interface library,SDI-12 USB Adapter
Nick Gammon
I would probably make whatever happens on the key into a function, and inside that do whatever until you detect it is no longer pressed. Say for example you turn on a light, just doing that multiple times won't turn the light off. So more like:
Code: [Select]
void button4pressed ()
  // turn light on
  while (kpd.getKey() == '4')
    {}   // wait for release
  // turn light off
  }  // end of button4pressed
More info:
teamhydraucd
Thank you, that explained a LOT.
Also, to save some pins on my microcontroller, is it possible to choose which part of the matrix keyboard I want functional ONLY?
for example, if I only wanted ['1' , '2' ; '4' , '5'] for a 2x2, can I just create the keyboard as a 2x2 matrix in my sketch and leave the rest nonfunctional?
liudr
Why would you need that? You don't have to use a matrix keypad. One pin for one key you use 4 keys, or two column by two row you also use 4 pins.
Nick Gammon
Liudr is right. You could conceivably do what you said, but you need 2 rows and 2 columns, so that is 4 inputs. You may as well just hook up 4 buttons.
But yes, you could connect up the first two columns and the first two rows and save 3 pins compared to what you are doing now.
More info:
teamhydraucd
I opted to just using the whole keypad.
Also, I used your suggestion to create a function to control the commands for when I press a specific button on the keypad. I haven't been able to test it out yet today since I'm currently out of town. The sketch compiled; but, my question is:
According to my current sketch, is the logic correct in terms of what I want it to do?
In other words, I want it so when I press '*' on the key pad, the servo will run as long as I hold it.
Code: [Select]
#include <Servo.h>
#include <Keypad.h>
#include <BMSerial.h>
#include <RoboClaw.h>
#define address 0x80
// Keypad Stuff
const byte ROWS = 4; // Four rows
const byte COLS = 3; // Three columns
// Define the Keymap
char keys[ROWS][COLS] = {
  {'1','2','3'},
  {'4','5','6'},
  {'7','8','9'},
  {'#','0','*'}
// Connect keypad ROW0, ROW1, ROW2 and ROW3 to these Arduino pins.
byte rowPins[ROWS] = { 3, 4, 5, 6 };
// Connect keypad COL0, COL1 and COL2 to these Arduino pins.
byte colPins[COLS] = { 0, 1, 2 };
// Create the Keypad
Keypad kpd = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
// Joypad Buttons
const int upA = 7;
const int downA = 8;
const int upB = 12;
const int downB = 13;
// Servo stuff
Servo myservo;  // Create servo object to control servo
int pos = 90; // Variable to store the servo position
// RoboClaw stuff
RoboClaw roboclaw(5,6);
int mSpeed = 64;
// HSR-1425CR controls
void buttonstarpressed ()
  while (kpd.getKey() == '*')
      for(pos; pos < 180; pos += 1) // Begin to rotate pressure washer from rest to full power
         myservo.write(pos);
         // Delay increase in "angle" by 10 ms before going through loop again
         delay(10);
  myservo.write(90);
void buttonpoundpressed ()
  while (kpd.getKey() == '#')
      for(pos; pos > 0; pos -= 1) // Begin to rotate pressure washer from rest to full power
          myservo.write(pos);
          delay(10);
  myservo.write(90);
  pinMode(upA, INPUT);
  pinMode(downA, INPUT);
  pinMode(upB, INPUT);
  pinMode(downB, INPUT);
  myservo.attach(11);  // "Attaches" HSR1425CR servo on pin 11
  myservo.write(pos);  // Initially set servo motor to zero movement ("90 degrees")
                    // Full power in direction 1: "0 degrees"
                    // Full power in direction 2: "180 degrees"
  Serial.begin(2400);
  // RoboClaw control
    if(digitalRead(upA) == LOW)
    roboclaw.ForwardM1(address, mSpeed);
    if(digitalRead(downA) == LOW)
    roboclaw.BackwardM1(address, mSpeed);
    if(digitalRead(upB) == LOW)
    roboclaw.ForwardM2(address, mSpeed);
    if(digitalRead(downB) == LOW)
    roboclaw.BackwardM2(address, mSpeed);
Nick Gammon
Quote
Well, no, because I don't see where buttonstarpressed is called.
Code: [Select]
You don't use "key" there so why find out what it is?
I would expect you to test (eg. switch on) the value of key and call the appropriate function.
More info:
teamhydraucd
Quote
Code: [Select]
I see...
Code: [Select]
buttonpoundpressed ();
buttonpoundpressed () {
while(kpd.getKey() == '#'){
// command to run until this is no longer valid
         myservo.write(pos);
         delay(10);
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
