Author Topic: Wind energy topic  (Read 263 times)
Hi all
In case of several wind generator placed in the same area , how their output are electrically combined ?
For example 3 wing generators placed in the same field , how their electrical output are combined into one
 single voltage so it will be used to drive the battery charger .
One way I thought is to rectify  each generator output and use blocking diodes
 to feed the charger in parallel .
But I am not sure , it's just an assumption ..
Thanks
Elico
Moderator edit: Shouty title reduced in volume
« Last Edit: April 25, 2012, 03:11:25 am by AWOL » Logged
If its a big installation there are specialized inverter/controllers that will do power-point tracking to get maximum power from each into the main bus.  For a smaller setup you might try something simpler like paralleling the outputs - rather assumes the generators are identical in identical atmospheric environments.  The engineering involved depends on a lot of factors.
South Texas
Sounds like you are thinking of several small wind generators for battery charging. If they supply DC the most you should have to do is put a large enough diode in each supply line so they can't back feed. This may not be necessary, depending on the design of the generators.
thanks
Elico
