Author Topic: Why orange  (Read 307 times)
When i write a function to turn a motor to go forward ie
void forward (int dist, int vel)                    // Forward function, dist is time in milliseconds, vel is speed
  digitalWrite(led,HIGH);
  digitalWrite(motor1pin, LOW);                     // Set H bridge pins to move both motors in the same direction
  digitalWrite(motor2pin, HIGH);
  digitalWrite(motor3pin, LOW);
  digitalWrite(motor4pin, HIGH);
  analogWrite (motor1speed, vel);                   // Turn on motor 1 by supplying a value 0-255 to En (pin 1)
  analogWrite (motor2speed, vel);                   // Turn on motor 2 by supplying a value 0-255 50 En (pin 9)
  delay (dist);                                     // keep both motors going for dist milliseconds
the forward command always appears in orange.
I have a similar setup to reverse the motor(s), that also becomes orange txt.
Now ive written code to spin 180 degrees. But the code looks ok but the spin function never turns orange, and doesnt work when I call it?
What is happenning?
What version of the IDE are you using? Can you post the code that is not working?
Is the word "forward" turning orange? I believe functions turn orange in the IDE, but the parameters passed to them stay black.
« Last Edit: April 25, 2012, 04:30:23 am by boredat20 » Logged
Gosport, UK
Assuming you mean the word 'forward' appears in orange text in the IDE, it would be because 'forward' is listed in one of the keywords.txt files. I presume spin isn't. If you want help to fix the problem, read http://arduino.cc/forum/index.php/topic,97455.0.html then post your sketch.
Seattle, WA USA
Seattle, WA USA
Color coding is based on the keywords.txt files delivered with each library.
Is that a question or a statement? If it is a statement, then what was the question? If it is a question, where is the spin() function code, and where do you call it?
What kind of motor are you talking about? I get the impression that the motor is a continuous rotation servo. If that is the case, you can't make it spin just 180 degrees.
Hi
Ive got the code working now. But i still dont understand why some functions are coloured orange like forward and reverse, whereas spin stays black.
int motor1pin = 3 ;                                //  H bridge pin 2
int motor2pin = 4 ;                                //  H bridge pin 7
int motor3pin = 6 ;                                //  H bridge pin 10
int motor4pin = 7 ;                                //  H bridge pin 15
int motor1speed = 9 ;                              //  To En pin 1: Use PWM to alter speed of motor 1
int motor2speed = 2 ;                             //  To En pin 9: Use PWM to alter speed of motor 2
int led = 13;
int dist;
int vel;
void setup ()
  pinMode (motor1speed, OUTPUT);                   // Define pins as outputs
  pinMode (motor2speed, OUTPUT);
  pinMode (motor1pin, OUTPUT );
  pinMode (motor2pin, OUTPUT );
  pinMode (motor3pin, OUTPUT );
  pinMode (motor4pin, OUTPUT );
  pinMode (led,OUTPUT);
void stop ()
  digitalWrite (motor1speed, LOW);                  // Make pin 1 (En) low to stop motor 1
  digitalWrite (motor2speed, LOW);                  // Make pin 9 (En) low to stop motor 2
  digitalWrite(led,HIGH);                           // just for debugging
void reverse (int dist, int vel)                    // Reverse function, just reverse HIGH and LOW commands
  digitalWrite(led,LOW);                            // just for debugging
  digitalWrite(motor1pin, HIGH);
  digitalWrite(motor2pin, LOW);
  digitalWrite(motor3pin, HIGH);
  digitalWrite(motor4pin, LOW);
  delay (dist);
void spin  (int dist, int vel)
  delay (dist);
 forward (5000,170);                               // forward for 5 seconds at about half speed
 stop ();                                          // stop both motors
 delay (2000);                                     // wait 2 seconds
 reverse (5000,170);                               // reverse
 stop();
 delay(2000);
 spin (1000,200);                                   // spin alter parameters to go 180 degrees
 stop ();
 delay (2000);
Gosport, UK
So you missed the bit about [code]...[/code] tags in point 6 of http://arduino.cc/forum/index.php/topic,97455.0.html
There are a number of files called keywords.txt that are supplied with some libraries (Arduino supplied and third-party). If a word (not a function) appears in one that the IDE can see, then it gets coloured.
« Last Edit: April 25, 2012, 04:54:46 am by dxw00d » Logged
Thanks and sorry about the tags. I havent loaded any libraries, do some get automatically included ?
Seattle, WA USA
Seattle, WA USA
Yes, a whole slew of them.
