Topic: Fitting a photoresistor into a car dashboard (Read 1 time) previous topic - next topic
Rejected666
For the car management system I'm currently building I use a photoresistor to detect whether to turn on the lights or not.
And I'm wondering what would be the best way to mount the resistor in my dash as cleanly as possible...
Any suggestions?
iyahdub
A panel mount clip maybe ?!? If its thin enough, u can use a Metal, panel mount bezel one, if not a clip one is better given the circumstances.
A few images so u get the idea.
http://www.rapidonline.com/catalogueimages/module/M079556P01WL.jpg
http://ledstuff.co.nz/images/LED-HLDR05Ba.jpg
http://i01.i.aliimg.com/photo/v0/295708783/10mm_Black_Plastic_Led_Clip_Holder_socket.jpg
10 LET Loop=Infinite
20 GO TO 10
Rejected666
It's a possibility, but since the photoresistor isn't round I will still have gaps at the sides...
keeper63@cox.net
Maybe switch to using a phototransistor; some come in cases like 3mm LEDs, then you can use standard LED panel mount clips...
I will not respond to Arduino help PM's from random forum users; if you have such a question, start a new topic thread.
Rejected666
Well, I've found lots of phototransistors in cases like 5mm LEDs, which would be ideal.
But they all seem to be intended for infrared :~
Would one like this: http://www.datasheetarchive.com/SFH300-4-datasheet.html be suitable for detecting visible light?
It says it has a range from 420 to 1130 nm, but below 700 nm the sensitivity doesn't look all that great...
Rejected666
I have finally found what I need on ebay: http://www.ebay.com/itm/260940362637
They are already in an enclosure and their peak sensitivity is right in the middle of the visible range :)
