Loading...
Pages: [1]   Go Down
Author Topic: new and delete now implemented in 1.0?  (Read 470 times)
0
Offline Offline
Newbie
Arduino rocks
View Profile
I've read a number of posts here in which it's claimed that C++ style "new" isn't implemented for Arduino. Which makes sense to me, since dynamic memory allocation in a memory-constrained environment is fraught with danger.
But I thought I would investigate for myself what the failure mode would be if I attempted to use "new." Imagine my surprise when I discovered that the following code compiles and runs on 1.0:
Code:
class Test {
public:
  int param;
  Test(int arg) {
    param = arg;
  static int done = 0;
  Test *t = 0;
  if (done==0) {
    Serial.print("1. t is ");
    Serial.println((uint16_t)t, HEX);
    t = new Test(123);
    Serial.print("2a. t is ");
    Serial.print("2b. t->param is ");
    Serial.println(t->param);
    delete t;
    done = 1;
I don't see anything on http://arduino.cc/en/Reference/Changes indicating that "new" is now supported. When did this change? (Perhaps an even more interesting question would be why did this change?)
M
Logged
0
Offline Offline
Full Member
Arduino rocks
View Profile
Yup, they are implemented in 1.0, along with pure virtual functions.  See http://arduino.cc/forum/index.php/topic,102453.0.html
I have not found and documentation of this change.
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
Thanks! I didn't find that post among the search results I looked at.
And agreed: "a small number of small objects", even in a small space, can be a fine thing. smiley
M
Logged
Global Moderator
Boston area, metrowest
Online Online
Brattain Member
Available for Design & Build services
View Profile
WWW
Not being an actual programmer: what does "new" do?
Logged
Designing & building electrical circuits for over 25 years. Check out the ATMega1284P based Bobuino and other '328P & '1284P creations & offerings at  www.crossroadsfencing.com/BobuinoRev17
Seattle, WA USA
Online Online
Brattain Member
Seattle, WA USA
View Profile
Quote
Dynamically allocates memory, to hold an instance of a class, and instantiates the class in that memory location, returning a pointer to it.
Logged
Global Moderator
Online Online
Brattain Member
View Profile
WWW
Seems like ovekill for a 1-byte variable, no?
Logged
Germany
Offline Offline
Edison Member
View Profile
I don't have an unused Arduino available right now, so:
What happens if you remove the last line
    done = 1;
Event if the Test class were bigger, I agree: it's questionable to use dynamic memory management on such a processor/memory, intended to run in an infinite loop.
Using new without catching the memory allocation exception is a bug.
What happens if you remove the second last line
    delete t;
Logged
0
Offline Offline
Faraday Member
20 LEDs are enough
View Profile
WWW
I also consider dynamic memory management somewhat critical with 2k of ram.
Let's wait and see how long it takes for the first template meta program to hit the Arduino platform smiley-wink
Logged
Check out my experiments http://blog.blinkenlight.net
Global Moderator
Online Online
Brattain Member
View Profile
WWW
"template meta program"
I don't even know that means!
I like '1284's with 16K of SRAM tho.
Logged
Global Moderator
Melbourne, Australia
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
Quote
What PaulS implied but didn't state outright is that a side-effect of "new" is that the constructor of the class is called, plus the constructors of any members of the class. This makes an important difference between doing "new" and "malloc" as "malloc" does not call constructors.
Quote
Indeed, but for larger variables you can save memory. Just as an example, if on the Mega2560 you wanted Serial1 but not Serial2 or Serial3, well the HardwareSerial library gives you all of them. Now if instead they let you do a "new" to create Serial1 if, and only if, you needed it, then the memory that it takes (eg. the buffers) are saved for perhaps more important uses ... that is, the memory is saved if you don't need it and don't call "new" on it.
Logged
Global Moderator
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
They didn't implement "placement new" which is a pity because some things like the STL use it.
Logged
Pages: [1]   Go Up
Print
Jump to:
