Topic: [URGENT] Comunication GPRS (Read 995 times) previous topic - next topic
nothunt
Hi!
I'm developing a project that needs GPRS communication to consume a webservice and retrive data. Does someone have or know code to do this?
Is it me or this comunication is really slow? Especially when we have to rely on this type on communication?
Thanks in advance!!
Best regards
LuisSoares
HI,
I would advise you to use Hilo module from Sagem.
Libelium designed a board to use it arduino compatible.
HiLo module
http://www.cooking-hacks.com/index.php/arduino-gprs-module.html
Nem model they have with SIM900, this i don´t know...
http://www.cooking-hacks.com/index.php/gprs-quadband-module-sim900-for-arduino.html
nothunt
Hi!
Thanks for the reply!! :)
I've got the Hilo module. But seems to me that tutorials I found only teach to send data to a Webservice but I do cannot find anything about gettting data from it.
Other issue its that this connection seems to be pretty slow.
best regards
LuisSoares
Yes it is a little bit slow but is one of the most robust modules i have tested.
We are using it to exchange big files and it takes some time to do so...
nothunt
Well lets say that I want the GPRS modeulo to ask to the webservice if it can enter the system and I would have 5 seconds to do it.
Could it possible? I'm just wondering because if it is too slow I'm thinking to swicth to RJ45.
LuisSoares
Well, it depends on the way you build the webservice.
To exchange small data, like login or small messages, i don´t see why it shouldn´t work.
But RJ45 would definitely be faster...
If you describe your application better, maybe we can help more
LuisSoares
Maybe this idea is better :
http://www.circuitsathome.com/mcu/interfacing-arduino-to-usb-gprs-modem
for example...
