Loading...
Pages: [1]   Go Down
Author Topic: Android + Arduino Bluetooth Connection Problem  (Read 842 times)
Offline Offline
Newbie
View Profile
Hi, I can get my Android app to connect via Bluetooth to my Arduino, however no data can be transmitted between them, below is my setup and code:
HTC Anroid v2.2
Bluetooth mate gold modem
Arduino Mega (ATmega1280)
Android Java code:
Code:
package com.example.BluetoothExample;
import android.app.Activity;
import android.bluetooth.BluetoothAdapter;
import android.bluetooth.BluetoothDevice;
import android.bluetooth.BluetoothSocket;
import android.content.Intent;
import android.os.Bundle;
import android.os.Handler;
import android.view.View;
import android.widget.TextView;
import android.widget.EditText;
import android.widget.Button;
import android.widget.Toast;
import java.io.IOException;
import java.io.InputStream;
import java.io.OutputStream;
import java.util.Set;
import java.util.UUID;
public class BluetoothExampleActivity extends Activity
    TextView myLabel;
    EditText myTextbox;
    BluetoothAdapter mBluetoothAdapter;
    BluetoothSocket mmSocket;
    BluetoothDevice mmDevice;
    OutputStream mmOutputStream;
    InputStream mmInputStream;
    Thread workerThread;
    byte[] readBuffer;
    int readBufferPosition;
    int counter;
    volatile boolean stopWorker;
    @Override
    public void onCreate(Bundle savedInstanceState)
     super.onCreate(savedInstanceState);
        setContentView(R.layout.main);
        Button openButton = (Button)findViewById(R.id.open);
        Button sendButton = (Button)findViewById(R.id.send);
        Button closeButton = (Button)findViewById(R.id.close);
        myLabel = (TextView)findViewById(R.id.label);
        myTextbox = (EditText)findViewById(R.id.entry);
        //Open Button
        openButton.setOnClickListener(new View.OnClickListener()
            public void onClick(View v)
                try
                    findBT();
                    openBT();
                catch (IOException ex) { }
        //Send Button
        sendButton.setOnClickListener(new View.OnClickListener()
                try
                    sendData();
                 showMessage("SEND FAILED");
        //Close button
        closeButton.setOnClickListener(new View.OnClickListener()
                try
                    closeBT();
    void findBT()
        mBluetoothAdapter = BluetoothAdapter.getDefaultAdapter();
        if(mBluetoothAdapter == null)
            myLabel.setText("No bluetooth adapter available");
        if(!mBluetoothAdapter.isEnabled())
            Intent enableBluetooth = new Intent(BluetoothAdapter.ACTION_REQUEST_ENABLE);
            startActivityForResult(enableBluetooth, 0);
        Set<BluetoothDevice> pairedDevices = mBluetoothAdapter.getBondedDevices();
        if(pairedDevices.size() > 0)
            for(BluetoothDevice device : pairedDevices)
                if(device.getName().equals("FireFly-108B"))
                    mmDevice = device;
        myLabel.setText("Bluetooth Device Found");
    void openBT() throws IOException
        UUID uuid = UUID.fromString("00001101-0000-1000-8000-00805f9b34fb"); //Standard SerialPortService ID
        mmSocket = mmDevice.createRfcommSocketToServiceRecord(uuid);
        mmSocket.connect();
        mmOutputStream = mmSocket.getOutputStream();
        mmInputStream = mmSocket.getInputStream();
        beginListenForData();
        myLabel.setText("Bluetooth Opened");
    void beginListenForData()
        final Handler handler = new Handler();
        final byte delimiter = 10; //This is the ASCII code for a newline character
        stopWorker = false;
        readBufferPosition = 0;
        readBuffer = new byte[1024];
        workerThread = new Thread(new Runnable()
            public void run()
               while(!Thread.currentThread().isInterrupted() && !stopWorker)
                    try
                        int bytesAvailable = mmInputStream.available();
                        if(bytesAvailable > 0)
                            byte[] packetBytes = new byte[bytesAvailable];
                            mmInputStream.read(packetBytes);
                            for(int i=0;i<bytesAvailable;i++)
                                byte b = packetBytes[i];
                                if(b == delimiter)
                                    byte[] encodedBytes = new byte[readBufferPosition];
                                    System.arraycopy(readBuffer, 0, encodedBytes, 0, encodedBytes.length);
                                    final String data = new String(encodedBytes, "US-ASCII");
                                    handler.post(new Runnable()
                                        public void run()
                                            myLabel.setText(data);
                                    readBuffer[readBufferPosition++] = b;
                        stopWorker = true;
        workerThread.start();
    void sendData() throws IOException
        String msg = myTextbox.getText().toString();
        msg += "\n";
        //mmOutputStream.write(msg.getBytes());
        mmOutputStream.write('A');
        myLabel.setText("Data Sent");
    void closeBT() throws IOException
        stopWorker = true;
        mmOutputStream.close();
        mmInputStream.close();
        mmSocket.close();
        myLabel.setText("Bluetooth Closed");
    private void showMessage(String theMsg) {
Toast msg = Toast.makeText(getBaseContext(),
theMsg, (Toast.LENGTH_LONG)/160);
msg.show();
Arduino Code:
Code:
#include <SoftwareSerial.h>
int bluetoothTx = 45;
int bluetoothRx = 47;
SoftwareSerial bluetooth(bluetoothTx, bluetoothRx);
  //pinMode(45, OUTPUT);
  //pinMode(47, INPUT);
  pinMode(53, OUTPUT);
  //Setup usb serial connection to computer
  //Setup Bluetooth serial connection to android
  bluetooth.begin(115200);
  bluetooth.print("$$$");
  delay(100);
  bluetooth.println("U,9600,N");
  bluetooth.begin(9600);
  //Read from bluetooth and write to usb serial
  if(bluetooth.available())
    char toSend = (char)bluetooth.read();
    Serial.print(toSend);
    flashLED();
  //Read from usb serial to bluetooth
  if(Serial.available())
    char toSend = (char)Serial.read();
    bluetooth.print(toSend);
    flashLED();
void flashLED()
  digitalWrite(53, HIGH);
  digitalWrite(53, LOW);
I've tried using 115200 and 9600 for the baud rates,
and I've tried setting the bluetooth rx and tx pins as input/output and output/input.
The Arduino is receiving serial data from the PC but can't send it to the Android (I can see this because of the flashLED() method). The Android can't send any data at all to the Arduino.
However they are both connected because the green light on the modem turns on and goes off and the red led flashes when I close the connection.
The sendData() method doesn't throw an exception because otherwise showMessage("SEND FAILED"); would appear.
Any help would be greatly appreciated!
Code take from: http://bellcode.wordpress.com/2012/01/02/android-and-arduino-bluetooth-communication/
« Last Edit: April 27, 2012, 12:42:56 am by frenzal_dude » Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Code:
You've got 4 f*ing hardware serial ports. Use one of them!
Logged
Offline Offline
Newbie
View Profile
thanks heaps!
That'd actually fixed the problem.
I'm using this code now:
Code:
  // see if there's incoming serial data:
  if (Serial.available() > 0) {
    // read the oldest byte in the serial buffer:
    incomingByte = Serial.read();
    if (incomingByte == 'a') {
However the LED always flashes whenever I send something from my Android, it doesn't have to be 'a'.
it seems that the Arduino is reading everything I send as 'a', does anyone know why this is happening?
This is my Android code for sending data:
Code:
Logged
Offline Offline
Newbie
View Profile
Have you tried using (switch case)  ex..
Code:
switch (recvChar) {
   case 'a':
I had same issue and someone pointed this out to me as well.....
 Hope it helps, it helped me
Logged
Pages: [1]   Go Up
Print
Jump to:
