Topic: Thermomètre avec DS18S20 et afficheur LCD i2c (Read 6668 times) previous topic - next topic
Mike74
#15
Apr 28, 2012, 07:26 pm Last Edit: Apr 29, 2012, 08:36 am by Jean-François Reason: 1
Bonjour et merci pour vos posts mais rien ne fonctionne , voici le bout de code que j'ai récupéré et modifier mais à la place de la température j'ai un carré qui s'affiche, j'ai un problème dans le traitement d'affichage de la variable.
Code: [Select]
#include <OneWire.h>
// OneWire DS18S20, DS18B20, DS1822 Temperature Example
// http://www.pjrc.com/teensy/td_libs_OneWire.html
// The DallasTemperature library can do all this work for you!
// http://milesburton.com/Dallas_Temperature_Control_Library
OneWire  ds(2);  // on pin 2
void setup(void) {
 Serial.begin(19200);
 ELCD_initialize();
 delay(200);
 ELCD_Clear_LCD();
 ELCD_Cursor_Position(0, 0);
 ELCD_put_str("Capteur");
 delay(30);
 ELCD_Cursor_Position(0, 1);
 ELCD_put_str("Temp.:");
 delay(30);
void loop(void) {
 byte i;
 byte present = 0;
 byte type_s;
 byte data[12];
 byte addr[8];
 float celsius, fahrenheit;
 ds.reset();
 ds.select(addr);
 ds.write(0x44,1);         // start conversion, with parasite power on at the end
 delay(1000);     // maybe 750ms is enough, maybe not
 // we might do a ds.depower() here, but the reset will take care of it.
 present = ds.reset();
 ds.select(addr);
 ds.write(0xBE);         // Read Scratchpad
 Serial.print("  Data = ");
 Serial.print(present,HEX);
 Serial.print(" ");
 for ( i = 0; i < 9; i++) {           // we need 9 bytes
   data[i] = ds.read();
   Serial.print(data[i], HEX);
   Serial.print(" ");
 Serial.print(" CRC=");
 Serial.print(OneWire::crc8(data, 8), HEX);
   // convert the data to actual temperature
 unsigned int raw = (data[1] << 8) | data[0];
 if (type_s) {
   raw = raw << 3; // 9 bit resolution default
   if (data[7] == 0x10) {
     // count remain gives full 12 bit resolution
     raw = (raw & 0xFFF0) + 12 - data[6];
   byte cfg = (data[4] & 0x60);
   if (cfg == 0x00) raw = raw << 3;  // 9 bit resolution, 93.75 ms
   else if (cfg == 0x20) raw = raw << 2; // 10 bit res, 187.5 ms
   else if (cfg == 0x40) raw = raw << 1; // 11 bit res, 375 ms
   // default is 12 bit resolution, 750 ms conversion time
 celsius = (float)raw / 16.0;
 ELCD_Cursor_Position(8, 2);
 ELCD_put_chr(celsius);
 delay(30);
 delay(1000); // On patiente une seconde
/* Initialize l'afficheur lcd */
void ELCD_initialize(){
 Serial.print(0xA0, BYTE);
/* Cache le curseur */
void ELCD_Cursor_OFF(){
 Serial.print(0xA3, BYTE);
 Serial.print(0x0C, BYTE);
/* Affiche le curseur */
void ELCD_Cursor_ON(){
 Serial.print(0x0E, BYTE);
/* Efface l'écran et place le curseur à (0, 0) */
void ELCD_Clear_LCD(){
 Serial.print(0x01, BYTE);
/* Place le curseur à la position (x, y) */
void ELCD_Cursor_Position(int x, int y){
 Serial.print(0xA1, BYTE);
 Serial.print(x, BYTE);
 Serial.print(y, BYTE);
/* Affiche une chaine de caractéres (char[] terminé par \0) sur l'afficheur */
void ELCD_put_str(char *str){
 Serial.print(0xA2, BYTE);
 while(*str)
   Serial.print(*str++);
 Serial.print(0, BYTE);
/* Affiche un caratéres ASCII sur l'afficheur (caractéres spéciaux aux LCD non pris en charge) */
void ELCD_put_chr(char ch){
 Serial.print(ch);
/* Définit un caractére personalisé à l'index défini (de 8 à 15) suivant le tableau newChar[],
  de structure identique à celui utilisé par la fonction createChar de la lib LiquidCrystal.
  Si showAfter = 1 le caractére sera afficher aprés la création, sinon il ne sera afficher qu'aprés un ELCD_put_chr(index) */
void ELCD_create_char(byte index, byte newChar[], byte showAfter) {
 if(showAfter)
   Serial.print(0xA4, BYTE);
   Serial.print(0xA5, BYTE);
 Serial.print(index, BYTE);
 Serial.print(newChar[0] & 0x1F, BYTE);
 Serial.print(newChar[1] & 0x1F, BYTE);
 Serial.print(newChar[2] & 0x1F, BYTE);
 Serial.print(newChar[3] & 0x1F, BYTE);
 Serial.print(newChar[4] & 0x1F, BYTE);
 Serial.print(newChar[5] & 0x1F, BYTE);
 Serial.print(newChar[6] & 0x1F, BYTE);
 Serial.print(newChar[7] & 0x1F, BYTE);
Merci pour votre aide.
barbudor
tu confond print() et write()
char a = 'A';
print( a ) -> envoi les octets 0x36 et 0x35 respectivement code ASCII des caractères 6 et 5 qui forment 65, le code ASCII de 'A'
write( a ) -> envoi l'octet 0x65 code ASCII de A
BYTE ?
Je ne connais pas. print() accepte uniquement comme 2nd paramètre DEC, BIN, DEC ou OCT
caco74
je ne vois aucune librairie concernant ton LCD.
barbudor
Et toutes les fonctions qui commencent par ELCD_, tu penses qu'elles servent à quoi ? ;)
caco74
merci du tuyau je decouvre des choses que je ne connaissais pas à part du lcd.print.
Mike74
#20
Apr 29, 2012, 09:04 am Last Edit: Apr 29, 2012, 09:18 am by Jean-François Reason: 1
Oui barbudor, tu as raison je n'ai pas encore créer la librairy qui est directement dans le code.
La solutions serait apparemment de convertir la variable en chaine de caractère String, comme défini par ce topic : http://arduino.cc/forum/index.php/topic,77866.msg588177.html#msg588177 et qui fonctionne très bien avec un capteur analogique mais pas avec un numérique.
Code: [Select]
void setup(void) {
 ELCD_initialize();
 delay(200);
 ELCD_Clear_LCD();
 delay(30);
 delay(30);
void loop(void) {
 byte i;
 byte present = 0;
 byte type_s;
 byte data[12];
 byte addr[8];
 ds.reset();
 ds.select(addr);
 ds.select(addr);
 Serial.print(" ");
   Serial.print(" ");
 if (type_s) {
 mesure_brute = (float)raw / 16.0;
 String texte = (String(mesure_brute)); // Conversion de la mesure en string
 ELCD_put_chr(texte.toCharArray());
 delay(30);
 while(*str)
 Serial.print(ch);
 if(showAfter)
Mais j'ai ce message d'erreur, je sèche .....
project01_pde.cpp:85:3: error: 'mesure_brute' was not declared in this scope
project01_pde.cpp:88:34: error: no matching function for call to 'String::toCharArray()'
C:\...........\mpide-0022-windows-20110822\hardware\pic32\cores\pic32/WString.h:80:10: note: candidate is: void String::toCharArray(char*, unsigned int)
osaka
Tu n'as tout simplement pas déclaré "mesure_brute"
J'ai pas regardé l'entièreté du code mais normalement :
Code: [Select]
float mesure_brute = (float)raw / 16.0;
char strF[8] = {0};
sprintf (strF, "%f", mesure_brute);
