Loading...
Pages: [1]   Go Down
Author Topic: 5x7 DOT MATRIX DISPLAY  (Read 1128 times)
Offline Offline
Newbie
View Profile
I am multiplexing a 5 column and 7 rows dot matrix. I connected like how this site connect. Direct connection http://arduino.cc/playground/Main/DirectDriveLEDMatrix . However i only uses 12pins. And for the code
http://hanez.org/arduino-ta07-11-5x7-dot-matrix-display.html i use exactly the same. Display do come out, but it make no sense to me -
Dont look like a alphabet, just random jumping .  BTW i'm using a common cathode 5x7 dot matrix. Maybe there is some problem with that?
Logged
Manchester (England England)
Offline Offline
Brattain Member
Solder is electric glue
View Profile
WWW
That tutorial is bad because there is no current limiting resistors on the LEDs, this could destroy your arduino. Do you have some in? If so what value and where?
http://www.thebox.myzen.co.uk/Tutorial/LEDs.html
Quote
A matrix is common anode or common cathode depending on the way round you look at it.
Quote
So set the code so that just one LED is to be on in a known place and see if it comes on in the place you expect it.
Logged
Offline Offline
Newbie
View Profile
There is a tutorial for controlling two 5x7 dot matrix LEDs at LucidTronix: http://lucidtronix.com/tutorials/18.  They use current-limiting resistors, and shift registers so it only take three signal wires.. They have an Arduino library you can download that can take text, or set individual pixels.
Logged
Samplefinger
Offline Offline
God Member
ALWAYS ASK FOR THREE. One to use. One to lose. One to abuse.
View Profile
Since this thread was resurrected I am going to mention that Maxim has a part that does specifically what the original poster asked for, it controls 1-4 5x7 matricies.  Who would have thunk it?
http://datasheets.maximintegrated.com/en/ds/MAX6952.pdf
Maxim has a bit of a premium on this chip but you can always ask for a sample.
« Last Edit: April 07, 2013, 02:46:16 am by JoeN » Logged
Latest Sampling Scores: ATXMEGA64A3U-MH x3, ATXMEGA256A3U-MH x3, SST38VF6404-90-5C-EKE x3, SST38VF6402-90-5C-EKE x3, PGA870 x3, THS770006 x3
Pages: [1]   Go Up
Print
Jump to:
