Loading...
Pages: [1]   Go Down
Author Topic: Ping Robo code error  (Read 494 times)
Offline Offline
Newbie
View Profile
My code for Ping robot.
There sumthing wrong in my code i cannot fix.
Please see LeftServo.refresh();
Code:
#include <Servo.h>     // includes the servo libs
Servo LeftServo;       // name the servo
Servo RightServo;      // name the servo
int ultraSoundSignal = 7; // Ultrasound signal pin
int val = 0;
int val2 = 0;
int ultrasoundValue = 0;
int timecount = 0; // Echo counter
int ledPin = 13; // LED connected to digital pin 13
int lightSense = 2;
int headLight = 8;
void setup(){
   pinMode(6,OUTPUT);
   pinMode(5,OUTPUT);
   LeftServo.attach(6); // Attaches the Left Servo to PWM pin 6 on the Arduino
   RightServo.attach(5); // Attaches the Right Servo to PWM pin 5 on the Arduino
   pinMode(headLight, OUTPUT);
   pinMode(lightSense, INPUT);
   beginSerial(9600);                  // Sets the baud rate to 9600
   pinMode(ledPin, OUTPUT);            // Sets the digital pin as output
void moveServoLeftTo(int angle, int duration){
  // command the servo to move to the given angle for the given number of milliseconds
   LeftServo.write(angle);
   for( ; duration > 0; duration -= 20){  // loop for the given number of milliseconds by subtracting 20ms each iteration
LeftServo.refresh();             // call the service routine to move the servo
delay(20);          // wait 20 milliseconds  between each refresh
void moveServoRightTo(int angle, int duration){
   RightServo.write(angle);
RightServo.refresh();            // call the service routine to move the servo
 // Ping))) functions: Doing more than I need it to, I think, but code
 timecount = 0;
 val = 0;
 pinMode(ultraSoundSignal, OUTPUT);   // Switch signalpin to output
  digitalWrite(ultraSoundSignal, LOW);  // Send low pulse
  delayMicroseconds(2);                 // Wait for 2 microseconds
  digitalWrite(ultraSoundSignal, HIGH); // Send high pulse
  delayMicroseconds(5);                 // Wait for 5 microseconds
  digitalWrite(ultraSoundSignal, LOW);  // Holdoff
  pinMode(ultraSoundSignal, INPUT);     // Switch signalpin to input
  val = digitalRead(ultraSoundSignal);  // Append signal value to val
  while(val == LOW) {                   // Loop until pin reads a high value
  while(val == HIGH) {                  // Loop until pin reads a high value
  timecount = timecount +1;           // Count echo pulse time
ultrasoundValue = timecount;          // Append echo pulse time to ultrasoundValue
if(timecount > 0){
  digitalWrite(ledPin, HIGH);
//delay(1);
// Servo functions: The basics
  if(ultrasoundValue > 500){
moveServoLeftTo(45,50);   // move the left servo to 45 degrees for 500 milliseconds
moveServoRightTo(180,50);  // moveRightTo function is left as an excercise ;)
  if(ultrasoundValue < 500){
      moveServoLeftTo(180,40);
      moveServoRightTo(180,40);
     if(ultrasoundValue < 100){
      moveServoLeftTo(180,100);
      moveServoRightTo(45,100);
      //moveServoLeftTo(45,50);
      //moveServoRightTo(180,50);
// Headlight - Turns on when photoresistor is triggered
// Doesn't seem to work on the same circuit... not sure why yet.
/*  val2 = digitalRead(lightSense);  // read input value
  if (val == HIGH) {            // check if the input is HIGH
    digitalWrite(headLight, LOW);  // turn LED OFF
    digitalWrite(headLight, HIGH); // turn LED ON
Moderator edit: code tags corrected.
« Last Edit: April 27, 2012, 12:10:49 pm by AWOL » Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
{code} is supposed to be [ code ] (without the spaces). Ditto for {/code}.
Quote
What would that something be? Aside from the fact that that is NOT how to read a ping sensor.
Logged
Gosport, UK
Offline Offline
Faraday Member
View Profile
Which servo library are you using? I don't recognise Servo.refresh().
Logged
Offline Offline
Newbie
View Profile
Sorry i dont know about the code as i copied it from sumwhere.
And also i dont know about library used.
if someone can provide me with the code for ping robot the help will be really really appreciated.
Logged
Gosport, UK
Offline Offline
Faraday Member
View Profile
I suggest you start with learning how to read a ping))) sensor - http://arduino.cc/en/Tutorial/Ping?from=Tutorial.UltrasoundSensor
Then look at the Servo library - http://arduino.cc/en/Reference/Servo
Logged
Offline Offline
Newbie
View Profile
Sorry after this also i cannot under stand.
One question-
How to make robot rotate 45 degree?
i have two servos.
OR
Make one servo stop to make other servo rotate?
Logged
Gosport, UK
Offline Offline
Faraday Member
View Profile
Are you using normal servos, or continuous-rotation servos?
Logged
Offline Offline
Newbie
View Profile
Logged
Gosport, UK
Offline Offline
Faraday Member
View Profile
Ok. They will be stopped when you set them to somewhere around 90 degrees. Settings higher or lower than the stop position will make them rotate in one direction or the other.
To make your robot rotate 45 degrees, assuming differential drive, you'll need to start the servos in opposite directions, and stop them after the robot has rotated as far as you want. If you have no wheel encoders, or any other way of getting rotational feedback, you'll have to experiment with the amount of time to run the servos.
Logged
Offline Offline
Newbie
View Profile
dxw00d ,please explain this with a code.
Logged
Gosport, UK
Offline Offline
Faraday Member
View Profile
Have you looked at the servo example sketches? Attach one of your servos, and try the 'Sweep' sketch. That should help you understand how the code works.
I was wrong earlier. To spin on the spot, both servos need to rotate in the same direction.
Logged
Offline Offline
Newbie
View Profile
Thank dxw00d.
Logged
Pages: [1]   Go Up
Print
Jump to:
