Topic: Ping Robo code error (Read 6784 times) previous topic - next topic
hugher256
Apr 26, 2012, 06:42 pm Last Edit: Apr 27, 2012, 07:10 pm by AWOL Reason: 1
My code for Ping robot.
There sumthing wrong in my code i cannot fix.
Please see LeftServo.refresh();
#include <Servo.h>     // includes the servo libs
Servo LeftServo;       // name the servo
Servo RightServo;      // name the servo
int ultraSoundSignal = 7; // Ultrasound signal pin
int val = 0;
int val2 = 0;
int ultrasoundValue = 0;
int timecount = 0; // Echo counter
int ledPin = 13; // LED connected to digital pin 13
int lightSense = 2;
int headLight = 8;
void setup(){
  pinMode(6,OUTPUT);
  pinMode(5,OUTPUT);
  LeftServo.attach(6); // Attaches the Left Servo to PWM pin 6 on the Arduino
  RightServo.attach(5); // Attaches the Right Servo to PWM pin 5 on the Arduino
  pinMode(headLight, OUTPUT);
  pinMode(lightSense, INPUT);
  beginSerial(9600);                  // Sets the baud rate to 9600
  pinMode(ledPin, OUTPUT);            // Sets the digital pin as output
void moveServoLeftTo(int angle, int duration){
 // command the servo to move to the given angle for the given number of milliseconds
  LeftServo.write(angle);
  for( ; duration > 0; duration -= 20){  // loop for the given number of milliseconds by subtracting 20ms each iteration
LeftServo.refresh();             // call the service routine to move the servo
delay(20);          // wait 20 milliseconds  between each refresh
void moveServoRightTo(int angle, int duration){
  RightServo.write(angle);
RightServo.refresh();            // call the service routine to move the servo
// Ping))) functions: Doing more than I need it to, I think, but code
timecount = 0;
val = 0;
pinMode(ultraSoundSignal, OUTPUT);   // Switch signalpin to output
 digitalWrite(ultraSoundSignal, LOW);  // Send low pulse
 delayMicroseconds(2);                 // Wait for 2 microseconds
 digitalWrite(ultraSoundSignal, HIGH); // Send high pulse
 delayMicroseconds(5);                 // Wait for 5 microseconds
 digitalWrite(ultraSoundSignal, LOW);  // Holdoff
 pinMode(ultraSoundSignal, INPUT);     // Switch signalpin to input
 val = digitalRead(ultraSoundSignal);  // Append signal value to val
 while(val == LOW) {                   // Loop until pin reads a high value
 while(val == HIGH) {                  // Loop until pin reads a high value
 timecount = timecount +1;           // Count echo pulse time
ultrasoundValue = timecount;          // Append echo pulse time to ultrasoundValue
if(timecount > 0){
 digitalWrite(ledPin, HIGH);
//delay(1);
// Servo functions: The basics
 if(ultrasoundValue > 500){
moveServoLeftTo(45,50);   // move the left servo to 45 degrees for 500 milliseconds
moveServoRightTo(180,50);  // moveRightTo function is left as an excercise ;)
 if(ultrasoundValue < 500){
     moveServoLeftTo(180,40);
     moveServoRightTo(180,40);
    if(ultrasoundValue < 100){
     moveServoLeftTo(180,100);
     moveServoRightTo(45,100);
     //moveServoLeftTo(45,50);
     //moveServoRightTo(180,50);
// Headlight - Turns on when photoresistor is triggered
// Doesn't seem to work on the same circuit... not sure why yet.
/*  val2 = digitalRead(lightSense);  // read input value
 if (val == HIGH) {            // check if the input is HIGH
   digitalWrite(headLight, LOW);  // turn LED OFF
   digitalWrite(headLight, HIGH); // turn LED ON
Moderator edit: code tags corrected.
PaulS
{code} is supposed to be [ code ] (without the spaces). Ditto for {/code}.
What would that something be? Aside from the fact that that is NOT how to read a ping sensor.
dxw00d
Which servo library are you using? I don't recognise Servo.refresh().
hugher256
Sorry i dont know about the code as i copied it from sumwhere.
And also i dont know about library used.
if someone can provide me with the code for ping robot the help will be really really appreciated.
dxw00d
I suggest you start with learning how to read a ping))) sensor - http://arduino.cc/en/Tutorial/Ping?from=Tutorial.UltrasoundSensor
Then look at the Servo library - http://arduino.cc/en/Reference/Servo
hugher256
Sorry after this also i cannot under stand.
One question-
How to make robot rotate 45 degree?
i have two servos.
OR
Make one servo stop to make other servo rotate?
dxw00d
Are you using normal servos, or continuous-rotation servos?
hugher256
dxw00d
Ok. They will be stopped when you set them to somewhere around 90 degrees. Settings higher or lower than the stop position will make them rotate in one direction or the other.
To make your robot rotate 45 degrees, assuming differential drive, you'll need to start the servos in opposite directions, and stop them after the robot has rotated as far as you want. If you have no wheel encoders, or any other way of getting rotational feedback, you'll have to experiment with the amount of time to run the servos.
hugher256
dxw00d ,please explain this with a code.
dxw00d
Have you looked at the servo example sketches? Attach one of your servos, and try the 'Sweep' sketch. That should help you understand how the code works.
I was wrong earlier. To spin on the spot, both servos need to rotate in the same direction.
hugher256
hugher256
This is my code. My servos are woking correctly, in opposite direction. But my pig sensor does not light up. I connected it to 5v port on Arduino. Any help will be really appreciated.
#include <Servo.h>
Servo ls;
Servo rs;
int val = 0;
int timecount = 0;
int signal =8;
int distance;
unsigned long pulseduration=0;
void setup(){
      pinMode(9,OUTPUT);
   pinMode(10,OUTPUT);
   ls.attach(9);
   rs.attach(10);
   pinMode(signal, OUTPUT);
Serial.begin(96500);
void measureDistance()
   // set pin as output so we can send a pulse
// set output to LOW
digitalWrite(signal, LOW);
// now send the 5uS pulse out to activate Ping)))
digitalWrite(signal, HIGH);
// now we need to change the digital pin
// to input to read the incoming pulse
pinMode(signal, INPUT);
   val = digitalRead(signal);  // Append signal value to val
if(timecount > 0){
// get the raw measurement data from Ping)))
measureDistance();
// divide the pulse length by half
pulseduration=pulseduration/2;
// now convert to centimetres. We're metric here people...
distance = int(pulseduration/29);
if( signal > 500){
   ls.write(0);
if( signal > 450){
   rs.write(0);
HazardsMind
#13
Apr 16, 2013, 08:50 pm Last Edit: Apr 16, 2013, 08:58 pm by HazardsMind Reason: 1
I have a few minor questions.
1) Why is your ping signal set as an output?
2) Why is this set the way it is. "Serial.begin(96500);"
3) How can "val = digitalRead(signal); " read anything if it is set as an output?
4) Why?
5) This is doing nothing, if(timecount > 0){ }
6) Where is pulseduration?
7) This will give you problems,
if( signal > 500){
   ls.write(0);
if( signal > 450){
   rs.write(0);
8 ) Why is this not in [ code ] [/ code] tags?
Last question, your pig sensor lights up?
My GitHub:
https://github.com/AndrewMascolo?tab=repositories
PaulS
Do you have a link to this pig sensor? I wonder if there is a cow sensor, too.
