Loading...
Pages: [1]   Go Down
Author Topic: 'BYTE' keyword is no longer supported  (Read 1477 times)
0 Members and 2 Guests are viewing this topic.
Offline Offline
Jr. Member
View Profile
Hi guys,
I am trying to compile the following code:
Code:
int sensorPin = 0; // Select input pin
int val = 0;
Serial.begin(9600); // Open serial port
val = analogRead(sensorPin)/4; // Read value from sensor
Serial.println(val,BYTE); // Print variable to serial port
delay(100); // Wait 100 milliseconds
It gives the following error:
Quote
As of Arduino 1.0, the 'BYTE' keyword is no longer supported.
Please use Serial.write() instead.
I have to send val to Processing in byte format.
How can I modify my code?
Thanks,
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Quote
I'd strongly suggest that you do as told, and use Serial.write() instead.
You can search the forum for the other 800 posts asking the same question.
Logged
Pages: [1]   Go Up
Print
Jump to:
