Author Topic: 'BYTE' keyword is no longer supported  (Read 1507 times)
Hi guys,
I am trying to compile the following code:
int sensorPin = 0; // Select input pin
int val = 0;
Serial.begin(9600); // Open serial port
val = analogRead(sensorPin)/4; // Read value from sensor
Serial.println(val,BYTE); // Print variable to serial port
delay(100); // Wait 100 milliseconds
It gives the following error:
As of Arduino 1.0, the 'BYTE' keyword is no longer supported.
Please use Serial.write() instead.
I have to send val to Processing in byte format.
How can I modify my code?
Thanks,
Seattle, WA USA
Online Online
Seattle, WA USA
I'd strongly suggest that you do as told, and use Serial.write() instead.
You can search the forum for the other 800 posts asking the same question.
