Topic: Recharging Car Battery with a Hack? [solved] (Read 1 time) previous topic - next topic
Apr 26, 2012, 11:04 pm Last Edit: Apr 27, 2012, 12:05 am by fkeel Reason: 1
My friends car has a dead battery. We don't know anyone around here who could help us immediately, but need the car asap.
I have a 12V, 17Ah Lead Acid battery, which someone left at my place about 18 months ago. It may or may not be charged. The only multimeter I have is rated for 13A, so I cant check it.
Should I just hook up the batteries and see what happens? Is there any way I can check the charge of the battery? I have a ton of electrical equipment lying around, but none of it is rated for high currents, and I am a bit skeptical of experimenting...
Any suggestions?
I think a 17Ah battery is a little underpowered compared to typical car batteries (I think they're in the ~50Ah range). But if it's fully charged it might work.
Your multimeter's current rating is not important, just set it to voltage measuring mode and measure the open-circuit voltage of your maybe-good battery. If it's not near 12V it has an even lower chance of working, as that indicates a non-fully-charged battery.
If you're careful, then yes, you can just hook up the batteries and see what happens. You do need big thick booster cables (else you'll lose a lot of whatever power you already have in the wiring, and in the worst case it will catch on fire). And make doubly sure you connect + to + and - to - (preferably, the dead battery - is not connected, but instead you connect the booster cable to a metal chassis point, like on the engine block, which is also -).
Wear eye protection, etc. etc.
The Ruggeduino: compatible with Arduino UNO, 24V operation, all I/O's fused and protected
I agree with RuggedCircuits.
I would add: If the battery has been lying around for 18 months it has to be of a very good quality battery to still be charged.
Good luck
Do not PM me a question unless you are prepared to pay for consultancy.
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
Coding Badly
I have two friends that independently have had a car battery explode.  Fortunately, the end result in both cases was damaged clothing.  The point of my post is...
>>>>> Wear eye protection, etc. etc. <<<<<
thanks for the suggestions guys. seems like the discussion is mute, as the battery is dead.
yeah... eye protection... its important. i learned that one the hard way...
I still remember the face of the lady at the reception when I told her that I had hydro-chloride acid in my eye :-D
I got lucky, but it changed my perspective on freak accidents...
Confirm your email address
Thank you for subscribing!
via Egeo 16
Torino, 10131
