Loading...
Pages: [1]   Go Down
Author Topic: Parallax LCD_2X16 example sketch  (Read 1348 times)
Offline Offline
Newbie
View Profile
Hey I am kind of new to arduino and was trying to get my parallax 27977 lcd display to work with the example sketch
Here:
Code:
  NOTE: you must: #include <NewSoftSerial.h>
  BEFORE including the ParallaxLCD.h header
#include <ParallaxLCD.h>
ParallaxLCD lcd(2,2,16); // desired pin, rows, cols
void setup () {
  lcd.setup();
  lcd.backLightOn();
  lcd.at(1,4,"Milliseconds\0");
  lcd.off();
  lcd.on();
  lcd.pos(0,1);
  lcd.at(2,7,"m:\0");
  for (int b=0; b<101; b+=5) {
    lcd.pos(0,3);
    lcd.at(2,9,millis());
  lcd.empty();
  lcd.print("Line Feed\0");
  for (int b=0; b<51; b+=5) {
    lcd.lf();
  lcd.empty();
  lcd.print("Chr Return\0");
    lcd.pos(0,11);
    lcd.cr();
  lcd.cursorBlock();
  lcd.empty();
  lcd.print("Block Cursor\0");
  for (int x=1; x<16; x++) {
    lcd.pos(1,x);
  lcd.empty();
  lcd.pos(1,1);
  lcd.cursorUnderline();
    lcd.pos(1,x);
  lcd.backLightOff();
  lcd.cursorOff();
void loop () {
But when i verify the sketch I get this:
In file included from LCD_2x16.cpp:11:
C:\Users\Mitchell Haley\Documents\Desk\gta and ard\ard\arduino-1.0\libraries\parallaxlcd/ParallaxLCD.h:23:22: error: WProgram.h: No such file or directory
C:\Users\Mitchell Haley\Documents\Desk\gta and ard\ard\arduino-1.0\libraries\parallaxlcd/ParallaxLCD.h:44: error: expected class-name before '{' token
C:\Users\Mitchell Haley\Documents\Desk\gta and ard\ard\arduino-1.0\libraries\parallaxlcd/ParallaxLCD.h:51: error: 'boolean' has not been declared
LCD_2x16.cpp: In function 'void setup()':
LCD_2x16.pde:-1: error: 'class ParallaxLCD' has no member named 'print'
Any and all help is greatly apreciated.
Moderator edit: [code] ... [/code] tags added. (Nick Gammon)
« Last Edit: April 27, 2012, 04:50:42 pm by Nick Gammon » Logged
Global Moderator
Melbourne, Australia
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
Code:
Read this before posting a programming question
See point 2.
Logged
Offline Offline
Newbie
View Profile
there was no #include "WProgram.h" in the code so I didn't worry about it. I did add #include "Arduino.h" and i still get alot of errors
Logged
Global Moderator
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
You need to edit this file:
Code:
At line 23 will be the include in question. Change that.
Logged
Offline Offline
Newbie
View Profile
Line 23 is   for (int b=0; b<101; b+=5) {
Logged
Global Moderator
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
Oh? Can you please post the first 30 lines of:
Logged
Global Moderator
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
It might save a considerable amount of time if you posted a link to this particular device, and a link to the exact library you are using. To save a lot of guessing.
Logged
Offline Offline
Newbie
View Profile
Sorry it didn't occur to me that it would be a problem with the library classes and here's the link http://www.cyberblob.net/parallaxlcd.zip
I fixed the Arduino.h problem and now I am getting this error
Logged
Global Moderator
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
OK, well it looks like it uses NewSoftSerial which is deprecated in version 1.0 of the IDE. I had to make a few changes to the library (attached) and a minor one to the sketch below:
Code:
  NOTE: you must: #include <SoftwareSerial.h>
void setup () {
  lcd.setup();
  lcd.backLightOn();
  lcd.off();
  lcd.on();
  lcd.pos(0,1);
  lcd.at(2,7,"m:\0");
    lcd.pos(0,3);
  lcd.empty();
    lcd.lf();
  lcd.empty();
    lcd.pos(0,11);
    lcd.cr();
  lcd.cursorBlock();
  lcd.empty();
    lcd.pos(1,x);
  lcd.empty();
  lcd.pos(1,1);
    lcd.pos(1,x);
  lcd.backLightOff();
  lcd.cursorOff();
void loop () {
Now it compiles OK.
Logged
Offline Offline
Newbie
View Profile
Thank you so much it worked perfectly
Logged
Georgia, US
Offline Offline
Jr. Member
View Profile
At least one person was helped. Maybe you could help me also.
I've downloaded the .cpp and the .h files and the sketch file and compiled with no errors but all I get on the display is "\" and the cursor advances one space; but only when I reset the arduino. No backlight or anything.
The self test via the switches does work and I have tried all three baud rates.
Any additional help will be greatly appreciated.
(and I'll wait until you Aussies wake up)
Winston
checking on another thread, I noticed that my TX/RX LEDs weren't flashing when I uploaded a program. COM port had been changed. one problem down, more to go.
Now I get the cursor moving about plus a few tones and after 30 seconds or so, it sounds like it's trying to play some tune. From the looks of the sketch; I don't think it's supposed to be playing any tunes.
« Last Edit: August 18, 2012, 07:49:47 pm by WinstonP » Logged
Global Moderator
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
Sounds like a wiring problem.
Logged
Georgia, US
Offline Offline
Jr. Member
View Profile
There's only 3 wires (5v, Gnd and data). Could the length of the wires be a problem. They're not shielded, only twisted, and 19" long (48cm) long. {I don't remember if ya'll use metric or not). I'll try a different jumper cable. one shorter and one shielded and try again.
Winston
Logged
Georgia, US
Offline Offline
Jr. Member
View Profile
Nevermind. I tried this code:
Code:
const int TxPin = 6;
SoftwareSerial mySerial = SoftwareSerial(255, TxPin);
  pinMode(TxPin, OUTPUT);
  digitalWrite(TxPin, HIGH);
  mySerial.begin(9600);
  delay(100);
  mySerial.write(12);                 // Clear
  mySerial.write(17);                 // Turn backlight on
  delay(5);                           // Required delay
  mySerial.print("Hello, world...");  // First line
  mySerial.write(13);                 // Form feed
  mySerial.print("from Parallax!");   // Second line
  mySerial.write(212);                // Quarter note
  mySerial.write(220);                // A tone
  delay(3000);                        // Wait 3 seconds
  mySerial.write(18);                 // Turn backlight off
from http://learn.parallax.com/KickStart/27977 and it works. My guess is a problem with the Parallax .h or .cpp code that's causing a problem.
Thanx anyways....
Winston
Logged
Pages: [1]   Go Up
Print
Jump to:
