Topic: MCP2300x behaviour (Read 1 time) previous topic - next topic
jopiek
I have a MCP23009 IC that I want to use as out put. So far so good, I used it once before as input and the ..17 as output, but...
I get a strange result. The LEDs will blink, but only if I connect them anode/plus to the V+ and cathode/minus to the mcp pin
This is the source:
#include <Wire.h>
#include "MCP23009.h"
// Basic toggle test for i/o expansion. flips pin #0 of a MCP23009 i2c
// pin expander up and down. Public domain
// Connect pin #1 of the expander to Analog 5 (i2c clock)
// Connect pin #2 of the expander to Analog 4 (i2c data)
// Connect pins #3, 4 and 5 of the expander to ground (address selection)
// Connect pin #6 and 18 of the expander to 5V (power and reset disable)
// Connect pin #9 of the expander to ground (common ground)
// Output #0 is on pin 10 so connect an LED or whatever from that to ground
// Note, based on MCP23009, but I modified it a bit
// (lib was originally made for mcp23008
// that code checks for addresses < 7 and my mcp has the address pin connected to 5V (and so has address 0x27)
MCP23009 mcp;
  mcp.begin(0x27);      // use default address 0
  for (int i=0; i< 8; i++)
    mcp.pinMode(i, OUTPUT);
// werkt wel, maar soms omgekeerd (dus de OUTPUT als GND?!)
// flip the pin #0 up and down
  for (int i=0; i< 8; i++) {
    //mcp.pinMode(i, OUTPUT);
    mcp.digitalWrite(i, HIGH);
    mcp.digitalWrite(i, LOW);
macegr
The MCP23009 outputs are open-drain.
Unique RGB LED Modules and Arduino shields: http://www.macetech.com/store
jopiek
Well, that explains a lot ;)
Thanks!!! So now I just need to rewire the signals...
