Topic: Redfly shield: request for advice and a general question (Read 889 times) previous topic - next topic
danimath
Hi Arduinoiers,
hope this is the correct sub-forum, but this deals roughly about installation (I hope).
I've just got a Watterott Redfly shield, and I'm eager to start with it. But before I have to solder the pins. Do you have any advice how to do this, so that the shield fits afterwards onto the arduino? I'm a little afraid of askew pins (big hands, smoker, coffee :smiley-red:).
And the general question is: what do you do, if you use shields with pin conflicts? E.g. PWM/3 seems to be a popular pin on many shields. So do you change shields with knife and soldering iron? Or is there any other magic?
Cordialità/best regards/cordialement/viele Grüße
Andreas
http://danimathblog.blogspot.com
#define true '/'/'/'
#define false '-'-'-'
James C4S
I like to put the header pins into a breadboard and then put the board on top of that.  Solder a single pin to orient the board and pins to 90°.  After that I solder every other pin taking 10-15 seconds between pin to allow them to cool and keep the breadboard from getting too much heat.
That's one way.  You can also use a shield made to be cut up like this one:
http://www.amazon.com/Add-Ohms-Arduino-Wuzzler-Shield/dp/B007APUR3I/ref=sr_1_1?ie=UTF8&qid=1335556644&sr=8-1
danimath
#2
Apr 28, 2012, 11:04 am Last Edit: Apr 28, 2012, 05:19 pm by danimath Reason: 1
Moin James,
("moin" is is a usual greeting in the northern part of germany and means "good day"  :D)
This way is not possible here, because the pins have to be put through the shield and soldered on the other side - so this way I had to solder between breadboard and shield. Meanwhile I did it (with trembling fingers  :)) and it worked quite well. I will post the pictures of the result this evening in my little blog.
Exactly what I looked for! Thanks for link!
best regards
Andreas
danimath
