Topic: Doing multiplication in trinary not displaying correctly. (Read 914 times) previous topic - next topic
Dartht33bagger
Hello everyone.  I am trying to make a program that multiplies two numbers in trinary and then displays the resulting number on 6 LEDs.  There are two input switches: the first one on pin 2 allows you to input the trinary number you want, and the second switch moves the program along in the multiplication process.  Here is the specifics of what I'm trying to accomplish:
Quote
Have your arduino do multiplication in trinary as follows:
Install two buttons.  The first button will be for entering numbers as above (push the button once to enter a 1, twice to enter a 2, etc).  The second button will be for multiplication and for clear.
Your arduino should operate like this procedure:
1.      Enter the first number on button 1.
2.      Press the button 2 for the multiplication symbol.
3.      Enter the second number on button 1.
4.      Arduino should display the first number times the second number in trinary.
5.      Press the button 2 to clear.
6.      Can repeat these steps to multiply a different two numbers without resetting the arduino.
I have created code that I think should work, but its not doing what I expect of it.  It allows me to enter in the first number on the first switch, and then when I click the second switch it allowed me to input the second number with the second switch.  Then when I hit the second switch again, nothing happens, and if I hit it again my program just restarts.  So what am I doing wrong, since this looks like it should work fine to me.
I will post my code below since it exceeds the max message size if I put it into this post.
Dartht33bagger
This part of the code seems to work fine:
Code: [Select]
int switchPin = 2;
int switchPin2 = 12;
int number1 = 0;
int number2 = 0;
int multNumber = 0;
int ledPins[] = {
  3,5,6,9,10,11};
int counter[] = {
  0,0,0,0,0,0};
int pinOn[] = {
  0,0,0,0,0,0};
boolean lastButton = LOW;
boolean lastButton2 = LOW;
boolean currentButton = LOW;
boolean currentButton2 = LOW;
boolean Stop = LOW;
  pinMode(switchPin, INPUT);
  pinMode(switchPin2, INPUT);
  for( int i = 0; i < 6; i++)
    pinMode(ledPins[i], OUTPUT);
  do
    currentButton = debounce( lastButton );
    currentButton2 = debounce2 ( lastButton2 );
    if(lastButton == LOW && currentButton == HIGH)
      number1 = number1 + 1;
      counter[0] = counter[0] + 1;
      //For 1 slot.
      if(counter[0] == 1)
        pinOn[0] = 128;
      else if(counter[0] == 2)
        pinOn[0] = 254;
      else if(counter[0] == 3)
        counter[0] = 0;
        pinOn[0] = 0;
        counter[1] = counter[1] + 1;
        counter[0] = 0;
        pinOn[0] = 0;
      //For 2 slot.
      if(counter[1] == 1)
        pinOn[1] = 128;
      else if(counter[1] == 2)
        pinOn[1] = 254;
      else if(counter[1] == 3)
        counter[1] = 0;
        pinOn[1] = 0;
        counter[2] = counter[2] + 1;
        counter[1] = 0;
        pinOn[1] = 0;
      //For slot 4
      if(counter[2] == 1)
        pinOn[2] = 128;
      else if(counter[2] == 2)
        pinOn[2] = 254;
      else if(counter[2] == 3)
        counter[2] = 0;
        pinOn[2] = 0;
        counter[3] = counter[3] + 1;
        counter[2] = 0;
        pinOn[2] = 0;
      //For slot 8
      if(counter[3] == 1)
        pinOn[3] = 128;
      else if(counter[3] == 2)
        pinOn[3] = 254;
      else if(counter[3] == 3)
        counter[3] = 0;
        pinOn[3] = 0;
        counter[4] = counter[4] + 1;
        counter[3] = 0;
        pinOn[3] = 0;
      //For slot 16
      if(counter[4] == 1)
        pinOn[4] = 128;
      else if(counter[4] == 2)
        pinOn[4] = 254;
      else if(counter[4] == 3)
        counter[4] = 0;
        pinOn[4] = 0;
        counter[5] = counter[5] + 1;
        counter[4] = 0;
        pinOn[4] = 0;
      //For slot 32
      if(counter[5] == 1)
        pinOn[5] = 128;
      else if(counter[5] == 2)
        pinOn[5] = 254;
      else if(counter[5] == 3)
        counter[5] = 0;
        pinOn[5] = 0;
        counter[5] = 0;
        pinOn[5] = 0;
      analogWrite(ledPins[i], pinOn[i]);
    if(lastButton2 == LOW && currentButton2 == HIGH)
      Stop = HIGH;
    lastButton = currentButton;
    lastButton2 = currentButton2;
  while (Stop == LOW);
  lastButton = LOW;
  lastButton2 = LOW;
  pinOn[0] = 0;
  pinOn[1] = 0;
  pinOn[2] = 0;
  pinOn[3] = 0;
  pinOn[4] = 0;
  pinOn[5] = 0;
  counter[0] = 0;
  counter[1] = 0;
  counter[2] = 0;
  counter[3] = 0;
  counter[4] = 0;
  counter[5] = 0;
  Stop = LOW;
  do
      number2 = number2 + 1;
      //For 1 slot.
      if(counter[0] == 1)
        pinOn[0] = 128;
        pinOn[0] = 254;
        counter[0] = 0;
        pinOn[0] = 0;
        counter[0] = 0;
        pinOn[0] = 0;
      //For 2 slot.
      if(counter[1] == 1)
        pinOn[1] = 128;
        pinOn[1] = 254;
        counter[1] = 0;
        pinOn[1] = 0;
        counter[1] = 0;
        pinOn[1] = 0;
      //For slot 4
      if(counter[2] == 1)
        pinOn[2] = 128;
        pinOn[2] = 254;
        counter[2] = 0;
        pinOn[2] = 0;
        counter[2] = 0;
        pinOn[2] = 0;
      //For slot 8
      if(counter[3] == 1)
        pinOn[3] = 128;
        pinOn[3] = 254;
        counter[3] = 0;
        pinOn[3] = 0;
        counter[3] = 0;
        pinOn[3] = 0;
      //For slot 16
      if(counter[4] == 1)
        pinOn[4] = 128;
        pinOn[4] = 254;
        counter[4] = 0;
        pinOn[4] = 0;
        counter[4] = 0;
        pinOn[4] = 0;
      //For slot 32
      if(counter[5] == 1)
        pinOn[5] = 128;
        pinOn[5] = 254;
        counter[5] = 0;
        pinOn[5] = 0;
        counter[5] = 0;
        pinOn[5] = 0;
      Stop = HIGH;
Dartht33bagger
This part of the code does not work correctly:
Code: [Select]
multNumber = number1 * number2;
  lastButton2 = LOW;
  pinOn[0] = 0;
  pinOn[1] = 0;
  pinOn[2] = 0;
  pinOn[3] = 0;
  pinOn[4] = 0;
  pinOn[5] = 0;
  counter[0] = 0;
  counter[1] = 0;
  counter[2] = 0;
  counter[3] = 0;
  counter[4] = 0;
  counter[5] = 0;
  Stop = LOW;
  for( int i = 0; i < multNumber; i++)
    //For 1 slot.
    if(counter[0] == 1)
      pinOn[0] = 128;
      pinOn[0] = 254;
      counter[0] = 0;
      pinOn[0] = 0;
      counter[0] = 0;
      pinOn[0] = 0;
    //For 2 slot.
    if(counter[1] == 1)
      pinOn[1] = 128;
      pinOn[1] = 254;
      counter[1] = 0;
      pinOn[1] = 0;
      counter[1] = 0;
      pinOn[1] = 0;
    //For slot 4
    if(counter[2] == 1)
      pinOn[2] = 128;
      pinOn[2] = 254;
      counter[2] = 0;
      pinOn[2] = 0;
      counter[2] = 0;
      pinOn[2] = 0;
    //For slot 8
    if(counter[3] == 1)
      pinOn[3] = 128;
      pinOn[3] = 254;
      counter[3] = 0;
      pinOn[3] = 0;
      counter[3] = 0;
      pinOn[3] = 0;
    //For slot 16
    if(counter[4] == 1)
      pinOn[4] = 128;
      pinOn[4] = 254;
      counter[4] = 0;
      pinOn[4] = 0;
      counter[4] = 0;
      pinOn[4] = 0;
    //For slot 32
    if(counter[5] == 1)
      pinOn[5] = 128;
      pinOn[5] = 254;
      counter[5] = 0;
      pinOn[5] = 0;
      counter[5] = 0;
      pinOn[5] = 0;
  do
      Stop = HIGH;
  lastButton = LOW;
  lastButton2 = LOW;
  pinOn[0] = 0;
  pinOn[1] = 0;
  pinOn[2] = 0;
  pinOn[3] = 0;
  pinOn[4] = 0;
  counter[0] = 0;
  counter[1] = 0;
  counter[2] = 0;
  counter[3] = 0;
  counter[4] = 0;
  Stop = LOW;
  number1 = 0;
  number2 = 0;
  multNumber = 0;
boolean debounce( boolean last )
  boolean current = digitalRead(switchPin);
  if( last != current)
    delay(5);
  return current;
boolean debounce2( boolean last2 )
  boolean current2 = digitalRead(switchPin2);
  if( last2 != current2)
    delay(5);
  return current2;
PeterH
#3
Apr 30, 2012, 10:39 am Last Edit: Apr 30, 2012, 10:52 am by PeterH Reason: 1
Is the bit in bold above correct? It doesn't seem to meet the requirements.
If it was me, I'd remove a lot of the duplication in that sketch by defining a function to input a number on switch 1, that ended when switch 2 was operated. This would be easy to test in isolation. THen your sketch would just call this twice, multiply the two numbers together and display the result.
I would also hold the numbers just as plain old integers instead of your array of trinary characters, and I'd do the number-to-trinary-display-format conversion at the point of displaying the number. You have to implement this anyway to display the answer, so you might as well do it to display the entered values. (This is easy enough to do by using div and mod to get the least significant digit repeatedly until the remainder is zero.)
IMO the crucial thing to keep in mind is that binary, hex, trinary, decimal etc are all just ways to display the number and do not change the number itself - you don't need to define a special representation of trinary numbers and write your own arithmetic operators and so on - they are just numbers, and only become trinary numbers at the point you format them (in trinary) for display. I would guess that your six LEDs are intended to provide three trinary digits each consisting of 0, 1 or 2 LEDs on. But maybe you have some other cunning way in mind to represent trinary digits using LEDs?
I only provide help via the forum - please do not contact me for private consultancy.
Nick Gammon
Code: [Select]
        pinOn[0] = 128;
        pinOn[0] = 254;
        pinOn[0] = 0;
and so on ...
I dislike "magic numbers". What are these 128, 254 and 0 of which you speak? What does it all mean? If they are "equivalent" given them a constant name, like foo, bar, and fubar. And explain what the constants mean. (I'm jesting about the exact names ... use ones that mean something).
Please post technical questions on the forum, not by personal message. Thanks!
More info:
http://www.gammon.com.au/electronics
Nick Gammon
Code: [Select]
  counter[0] = 0;
  counter[1] = 0;
  counter[2] = 0;
  counter[3] = 0;
  counter[4] = 0;
  counter[5] = 0;
And read up on "for" loops.
Code: [Select]
for (byte i = 0; i <= 5; i++)
  counter [i] = 0;
More info:
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
