Topic: Which components should I buy? (Read 642 times) previous topic - next topic
PatrickEE
Hello.  I recently purchased an Arduino Mega 2560 and a breadboard.  I want to develop some sketches involving servos, leds, potentiometers, photoresistors, and accelerometers.  My question is what values of resistors and capacitors should I get to start creating some prototypes on my breadboard?  Most the beginner projects on the Arduino site use 220 ohm resistors, but I am thinking that I may need a wide range of resistance due to the variety of components I am working with.  Any help would be greatly appreciated.  Thanks.
CrossRoads
So get a wide range of parts then.
http://www.dipmicro.com/store/SET-CK1
http://www.dipmicro.com/store/SET-EC2
http://www.dipmicro.com/store/SET-RF405
PatrickEE
Great links.  Thanks for the information.
jwatte
Jameco has "grab bags" of parts, and Amazon has "assortments" of parts.
However, you will get far on a set of 220, 1k and 10k resistors and 0.1, 10 and 470 uF capacitors (25V or better, higher for the 0.1 uF ceramic). Add a dozen BS170 mosfets for switching load, a grab bag of LEDs for indication, some switches, and a solderless breadboard with jumper wires and alligator clips, and you have good basics. The mosfets can even serve as diodes!
Next up is a multimeter and a bench power supply. Perhaps some LM317 or LM1117 or similar for voltage regulation. MC602 opamps, shottky diodes (1A 50V) and a variety of connectors would be icing.
After that, you need to be more specific in what you are trying to build.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
