Hi.
I am working on a project using the Arduino and Max/MSP to control light via DMX.
In the sketch, I need the Arduione to read incoming button presses, midi, and ethernet messages constantly.
Therefore, I would like to have a loop() that runs constantly, checking for incoming data of the
mentioned kinds (with minimum delay). My question is: is it necessary to have a delay(ms) in my loop function?
- will the Arduino overheat, crash, explode or something if I do not have a delay()?
I have pasted my code, at its current state below.
Best regards Jakob
#include <SPI.h>
#include <Ethernet.h>
#include <ArdOSC.h>
#include <DmxSimple.h>
// Define pin number for midi shield enable
# define MIDI_EN 17
byte myMac[] = { 0x90, 0xA2, 0xDA, 0x00, 0xFB, 0x00 };
byte myIp[] = { 192, 168, 1, 177 };
int destPort=7400;
byte destIp[] = { 192, 168, 1, 176 };
OSCClient client;
//create new osc message
OSCMessage global_mes;
OSCServer server;
int serverPort = 7401;
//Button
int buttonPressedLast = 0;
//Max connection
boolean hasConnection = false;
long lastPing = 0;
void setup(void)
Serial.begin(31250); //Midi
pinMode(MIDI_EN, OUTPUT);
digitalWrite(MIDI_EN, HIGH);
pinMode(5, OUTPUT);
pinMode(6, OUTPUT);
Ethernet.begin(myMac ,myIp);
server.begin(serverPort);
server.addCallback("DMX",&sendDMX);
server.addCallback("ping",&pingReceived);
//Udp receive
if(server.aviableCheck()>0)
//printToMax("Server available");
//Midi input handling
uint8_t event, note, velocity;
if (Serial.available())
event = Serial.read();
if (event == 0xFE) return; // System activity heartbeat
if ((event & 0xE0) == 0x80)
{ // Note-on event or note-off event
while (! Serial.available()) /* NULL */ ;
note = Serial.read();
velocity = Serial.read() ;
sendNoteEvent(event, note, velocity);
//Read analog in on A0, button presses
int aIn = analogRead(A0);
if(aIn > 100)
buttonPress(aIn);
else if (buttonPressedLast > 0)
digitalWrite(6, LOW);
buttonOff(buttonPressedLast);
//If hasConnection, check if connection is lost
if (hasConnection)
if ((millis() - lastPing) > 2000) //if 2 seconds have passed since last ping...
digitalWrite(5, LOW);
//delay(some amount of ms ?);
void sendDMX(OSCMessage *_mes)
int channel = _mes->getArgInt32(0);
int value = _mes->getArgInt32(1);
DmxSimple.write(channel, value);
printToMax("DMX sent");
void printToMax(char str[])
global_mes.setAddress(destIp,destPort);
global_mes.beginMessage("print");
global_mes.addArgString(str);
client.send(&global_mes);
global_mes.flush(); //object data clear
void buttonPress(int val)
int button = 0;
if (val >= 950)
button = 1;
else if (val >= 700)
button = 2;
else if (val >= 450)
button = 3;
button = 4;
if (button != buttonPressedLast)
digitalWrite(6, HIGH);
if (buttonPressedLast != 0)
buttonPressedLast = button;
global_mes.beginMessage("button");
global_mes.addArgInt32(button);
global_mes.addArgInt32(1);
void buttonOff(int button)
global_mes.addArgInt32(0);
void pingReceived(OSCMessage *_mes)
lastPing = millis();
if (! hasConnection)
hasConnection = true;
digitalWrite(5, HIGH);
// Send note-on or note-off to Max
void sendNoteEvent(uint8_t event, uint8_t note, uint8_t velocity)
// MIDI command 0x80 is note off...also accept note-on with velocity 0 as a note-off event
if ( ((event & 0xF0) == 0x80) || (velocity==0) )
global_mes.beginMessage("note");
global_mes.addArgInt32(note);
else if ((event & 0xF0) == 0x90)
{ // Note on...should always be true by this point
global_mes.addArgInt32(velocity);
