Loading...
Pages: [1]   Go Down
Author Topic: 4 5x7 DOT MATRIX DISPLAY  (Read 1001 times)
Offline Offline
Newbie
View Profile
Hi, guys.
I'm trying to do a project using four 5x7 led dot matrix display. How do i go about configuring the hardware? Do i need ULN2803 , 74HC595 shift register to program it? Can you guys give some links on how i should set up ? Thanks very much
Logged
South England
Offline Offline
Full Member
View Profile
You can use the MAX7219 to do that. Details here: http://arduino.cc/playground/Main/LedControl
Logged
Offline Offline
Newbie
View Profile
But they never teach me how to setup.
Logged
Offline Offline
Newbie
View Profile
I try to connect all the column to 74hc595, what should i do with the rows? http://www.arduino.cc/en/Tutorial/ShiftOut say connect all to ground ?
Logged
Manchester (England England)
Offline Offline
Brattain Member
Solder is electric glue
View Profile
WWW
You need to understand what is happening when you multiplex a device. Read this:-
http://www.thebox.myzen.co.uk/Workshop/LED_Matrix.html
Logged
Offline Offline
Newbie
View Profile
hey, i include the uln2803. but i wan reduce the number of pins. that why i'm using 74hc595.
Logged
Offline Offline
Brattain Member
View Profile
WWW
Fine, if you don't want it to actually work then you can miss out the shift registers altogether.
Logged
Offline Offline
Newbie
View Profile
Nice tutorial with shift registers and current-limiting resistors at http://lucidtronix.com/tutorials/18.  They've got an Arduino library that can display string or set individual pixels.
Logged
Pages: [1]   Go Up
Print
Jump to:
