Loading...
Pages: 1 [2] 3   Go Down
Author Topic: Strobe  (Read 1137 times)
Offline Offline
Full Member
View Profile
No I have it set to 3, the number of chips I have. And even if that was wrong and it was still set to 1 chip shouldnt I still be able to get to 5 rgb Leds since 5*3 = 15 and that is still less than the chips 16 outputs? How many bits can serial send at a time?
Logged
Manchester (England England)
Offline Offline
Brattain Member
Solder is electric glue
View Profile
WWW
Quote
The serial port sends one byte at a time, do you mean that?
Is your power supply up to the current? Have you got good decoupling on each chip.
What happens if you remove the first LED and have the last one on. Does it still fall over?
Logged
Offline Offline
Full Member
View Profile
So the text box can hold any amount and there isnt any limiting factor in the serial? Yes they are decoupled, Yes I can set it to any pins I want as long as I dont use more than 4
Logged
Offline Offline
Brattain Member
View Profile
WWW
I think it is time to put some debug output in the code to see if the values are being set like you think they are.
Logged
Offline Offline
Full Member
View Profile
Ok, I will try that and post results
Logged
Offline Offline
Full Member
View Profile
Quick question, is there a point where the value of Serial.Available becomes high enough that the arduino deletes some bytes?
Logged
Offline Offline
Full Member
View Profile
The serial buffer on the arduino is 128 bytes, and with 15 per rgb led thats only 60 bytes. So If I add one more led thats 75 bytes. But I am using a teensy++, and this section in the manual might provide an answer to why, but not how to solve the problem. The Teensy++ can only have 64 bytes in the buffer at a time? How do I solve this?
Quote
Receive Buffering
When the PC transmits, usually the host controller will send at least the first USB packet within the next 1ms. Both Teensyduino and the FTDI chip on Arduino receive a full USB packet (and verify its CRC check). The FTDI chip then sends the data to a standard Arduino via slow serial. A sketch repetitively calling Serial.available() and Serial.read() will tend to see each byte, then many calls to Serial.availble() will return false until the next byte arrives via the serial communication.
On a Teensy, the entire packet, up to 64 bytes, becomes available all at once. Sketches that do other work while receiving data might depend on slow reception behavior, where successive calls to Serial.available() are very unlikely to return true. On a Teensy receiving large amounts of data, it may be necessary to add a variable to count the number of bytes processed and limit the delay before other important work must be done.
Logged
Offline Offline
Full Member
View Profile
Ok this works
Code:
#include <Tlc5940.h>
/* Blink Multiple LEDs without Delay
* Turns on and off several light emitting diode(LED) connected to a digital
* pin, without using the delay() function.  This means that other code
* can run at the same time without being interrupted by the LED code.
const int NUMRGBLEDS = 56;    //number of rgb leds
const int pin[NUMRGBLEDS] = {0,3,6,9,12,15,18,21,24,27,30,33,36,39,42,45,48,51,54,57,60,63,67,70,73,76,79,82,85,88,91,94,97,100,103,106,109,112,115,118,121,124,127,130,133,136,139,142,145,148,151,154,157,160,163,166};  //   first tlc5940 pin of every rgb led
const int NUMCHANNELS = 280; //# of rgb led's times 5
byte state[NUMRGBLEDS];   //  Leave this alone
unsigned int RedVal[NUMRGBLEDS];   //  Leave this alone
unsigned int GreenVal[NUMRGBLEDS];   //  Leave this alone
unsigned int BlueVal[NUMRGBLEDS];   //  Leave this alone
unsigned int Value[NUMCHANNELS];   //  Leave this alone
unsigned long time[NUMRGBLEDS];    //  Leave this alone
  Serial.println("Initializing...");
Tlc.init();
Serial.println("Ready");
 if (Serial.available() == (64)) {
   for (unsigned int i=0; i < NUMCHANNELS; ++i){
    Value[i] = (Serial.read() - '0') * 100;
    Value[i] = Value[i] + (Serial.read() - '0') * 10;
    Value[i] = Value[i] + (Serial.read() - '0');
 Serial.print("You Sent: ");
 Serial.print(Value[i] , DEC);
 Serial.print("-");
   for (unsigned int i=0; i<NUMRGBLEDS; ++i){
   RedVal[i] = Value[i*5] * Value[i*5 + 3] / 255;
   GreenVal[i] = Value[(i*5) + 1] * Value[(i*5) + 3] / 255;
   BlueVal[i] = Value[(i*5) + 2] * Value[(i*5) + 3] / 255;
if (Value[((i*5)+4)] > 0){
  unsigned long m = millis();
   if (state[i] == 1){
      if (m - time[i] > 15)
     time[i] = m;
     state[i] = 0;
     Tlc.set(pin[i], 0);
     Tlc.set(pin[i] + 1, 0);
     Tlc.set(pin[i] + 2, 0);
   else{
   if (m - time[i] > (Value[((i*5)+4)] * 8) - 15)
     time[i] = m;
     state[i] = 1;
     Tlc.set(pin[i], map(RedVal[i], 0,255,0,4095));
     Tlc.set(pin[i] + 1, map(GreenVal[i], 0,255,0,4095));
     Tlc.set(pin[i] + 2, map(BlueVal[i], 0,255,0,4095));
else{
     Tlc.set(pin[i], (map(RedVal[i], 0,255,0,4095)));
     Tlc.set(pin[i] + 1, (map(GreenVal[i], 0,255,0,4095)));
     Tlc.set(pin[i] + 2, (map(BlueVal[i], 0,255,0,4095)));
    Tlc.update();
Logged
Offline Offline
Full Member
View Profile
Grumpy_Mike do you see any ways I could streamline the code? Specifically the refresh speed?
Logged
Offline Offline
Brattain Member
View Profile
WWW
Code:
Do not wait until all the bytes are sitting in the buffer. Pull them out when there are three or more in the buffer and keep a count of how many you read. Stop looking for stuff to arrive once you have counted the right number of bytes.
Instead of using:-
Code:
map(RedVal[i], 0,255,0,4095)[code]
Just shift the number 4 places to the left, in effect multiplying by 16 like this:-
[code]RedVal[i] << 4
It is much faster.[/code][/code]
Logged
Offline Offline
Full Member
View Profile
On the first suggestion, the teensy provides 64 bytes an one time because it is a native usb device. Does that still apply then?
Logged
Offline Offline
Brattain Member
View Profile
WWW
Quote
Well the packet size of a USB device is 1K, if it only fills 64 bytes of it then it is because of memory constraints. I still think you are better off taking them out a few at a time then the driver can manage the request for more data in a way that is probably going to increase the throughput.
Logged
Offline Offline
Full Member
View Profile
Ok. And is there any more I can do? The strobe needs to be faster because it cant go as fast as I'd like it to.
Logged
Offline Offline
Brattain Member
View Profile
WWW
How fast does it need to be?
You could do something like pre load the shift registers and toggle the blank pin, but you probbly need to hack into the libary for that.
Logged
Offline Offline
Full Member
View Profile
Not  that much faster, but as fast as possible
Logged
Pages: 1 [2] 3   Go Up
Print
Jump to:
