Topic: Strobe (Read 5924 times) previous topic - next topic
Grumpy_Mike
Well don't send the data as ASCII numbers, just send byte pairs, so that is one less serial transfer per LED and you don't have to do multiplying.
ematson5897
How would I do that? And since the sketch won't permanently be serial based, couldnt I just find the ascii value of the input number for now? Evuntually it will use dmx
Grumpy_Mike
What exactly is the time you are trying to minimise?
You could skip the bit that spits all the values back to the serial port.
I am not sure what this is doing:-
Code: [Select]
   RedVal[i] = Value[i*5] * Value[i*5 + 3] / 255;
   GreenVal[i] = Value[(i*5) + 1] * Value[(i*5) + 3] / 255;
   BlueVal[i] = Value[(i*5) + 2] * Value[(i*5) + 3] / 255;
but a multiply and then a dived by 255 is time consuming. Why 255? I would have though 256 and then you can do it with a simple shift.
Have you remove the map() function, I spoke about before?
ematson5897
Since the program also has a dimmer  that dims the whole rgb mix, that code has to be there. It calculates the values for rgb for the leds. If I used two atmega chips where one works with dmx and calculates those values and the other updates the leds, how much would the speed increase?
Grumpy_Mike
Quote
No idea,
Try it by removing those calculations and see the speed.
