Loading...
Pages: [1]   Go Down
Author Topic: How to fade all 20 pins in and out ...  (Read 625 times)
Global Moderator
Melbourne, Australia
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
I got inspired by the recent post from someone who wanted to copy an input bit to an output. So I thought "why not use that to fade all 20 pins?".
This sketch is the result. It's based on the Fade example, but by adding in a pin change interrupt, we detect when the pin (pin 9) is pulsed and make all the other pins mirror it. Thus, all 20 pins fade in and out together.
Code:
int brightness = 0;    // how bright the LED is
int fadeAmount = 5;    // how many points to fade the LED by
const byte pwmPin = 9;
const byte maxPin = 19;
ISR (PCINT0_vect)
static byte val = 0;
 val = !val;
 for (byte i = 0; i <= maxPin; i++)
   if (i != pwmPin)
     digitalWrite (i, val);
    pinMode (i, OUTPUT);
  // pin change interrupt
  PCMSK0 = _BV (PCINT1);  // only want pin 9
  PCIFR  = _BV (PCIF0);   // clear any outstanding interrupts
  PCICR |= _BV (PCIE0);   // enable pin change interrupts for PCINT7..0
  }   // end of setup
  // set the brightness of pin 9:
  analogWrite(pwmPin, brightness);
  // change the brightness for next time through the loop:
  brightness = brightness + fadeAmount;
  // reverse the direction of the fading at the ends of the fade:
  if (brightness == 0 || brightness == 255)
    fadeAmount = -fadeAmount ;
  // wait for 30 milliseconds to see the dimming effect
  delay(30);
}  // end of loop
Logged
Global Moderator
Boston area, metrowest
Offline Offline
Brattain Member
Available for Design & Build services
View Profile
WWW
Okay, now arrange the 20 pins in a circle, and work the fade up & down around the circle ...
Logged
Designing & building electrical circuits for over 25 years. Check out the ATMega1284P based Bobuino and other '328P & '1284P creations & offerings at  www.crossroadsfencing.com/BobuinoRev17
Global Moderator
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
Let me get my hammer and saw ...
It's a bit silly, I know, because you could just make a loop anyway that did it. But still it shows how you can mirror what is on one pin to be on another one if you need to.
Logged
0
Offline Offline
Faraday Member
20 LEDs are enough
View Profile
WWW
Nice for learning but it shows a significant amount of flicker. Most probably due to the slow digitalWrites. I would implement it along the lines of my knight rider http://blog.blinkenlight.net/experiments/removing-flicker/knight-rider-no-flicker/ or heartbeat http://blog.blinkenlight.net/experiments/removing-flicker/heartbeat/ examples.
Logged
Check out my experiments http://blog.blinkenlight.net
Netherlands
Offline Offline
Tesla Member
In theory there is no difference between theory and practice, however in practice there are many...
View Profile
Code:
   if (i != pwmPin)
use direct port manipulations?
Logged
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
Global Moderator
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
Yes you could do that, but it obscures the basic idea, that you can react to a pin changing. It isn't fabulously practical as such (there would be easier ways of fading 20 LEDs).
Actually what would be interesting would be to try to make a ripple effect, and make use of the delay (eg. pin 1 causes pin 2 to change which causes pin 3 to change and so on).
Logged
Global Moderator
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
OK, if you replace the ISR with:
Code:
ISR (PCINT0_vect)
 if (PINB & _BV (1))   // D9
   PORTB = PORTC = PORTD = 0xFF;
   PORTB = PORTC = PORTD = 0;
Then it is smoother.
I would implement it along the lines of my knight rider ... examples.
Done! And I tested with your Blinkenlight Shield, Udo.
Logged
Pages: [1]   Go Up
Print
Jump to:
