Topic: smoothing pot input (Read 5508 times) previous topic - next topic
db2db
Googling arund I found this smoothing algorithm. Seems simple, but I follow how it would work.
// declared globally
float smoothADC;
// inside loop() or other repeating function
smoothADC = 0.9 * smoothADC + 0.1 * analogRead(0);
Make sense to anyone?
skyjumper
No, that makes no sense as written. Are you sure nothing is omitted? That code uses an uninitialized variable, which can never ever work.
skyjumper
What you could do instead is save the last n values and average them. Depending upon the nature of the data that is an easy way to do it that can work well.
Coding Badly
It's an "exponentially weighted moving average" or EMWA (missing the proper initialization as skyjumper mentioned).
bubulindo
I think he asked if the algorithm is correct, not if the code was properly written. And it is only the initialization of the variable that is missing (which most likely is cleared and set in more than one place in the code).
That formula you have is a sort of averaging filter. Weighed average I think may be a better name for it.
Basically you have this:
smooth = ((smooth * 9) + analogRead(0))/10;
So every new sample has an effect of 10% in your signal. A little Excel sheet can do wonders to show the result of this and different weights applied to this formula.
This... is a hobby.
skyjumper
Can a filter like this be used to smooth the last n samples, so that old data is at some point essentially discarded? Currently I am storing the last 20 samples and averaging them, but I have been looking for a way to achieve this without consuming 80 bytes (20 floats)...
Grumpy_Mike
I think you are missing the point after many iterations the old data is so diluted that it has no effect, this is not homeopathic computing.
The alternative is to use an array and apply a different weighting to each sample. In this way any required filter response can be created providing you have enough terms. However, the increase in processing time reduces the top frequency of the filter. This sort of programming is known as digital signal processing.
Coding Badly
A follow-up to @Grumpy_Mike's answer: Assuming your samples are integers (e.g. from the analog-to-digital converter), using db2db's ? = 0.9, the contribution for the seventh previous value becomes so small that it is not present in a float.  In other words, for practical purposes it's zero.  ? = 0.9 gives a history of six samples (the contribution of the six is 1 / 1E-06; not much).
What are you trying to achieve?  Is the goal to filter out noise when reading a stable signal (in which case the "windowed average" you're doing now is probably the right choice)?  Do you need the average to "respond quickly" to signal changes?
db2db
#8
Apr 29, 2012, 10:04 pm Last Edit: Apr 29, 2012, 10:06 pm by db2db Reason: 1
This seems to work, but is very slow to respond. How can I speed up the response?
float smooth ;
SSerial.print(analogRead(5));  //show raw output of pot value
SSerial.print(" ");                  // add a space for readibility
smooth = 0.9 * smooth + 0.1 * analogRead(5);
SSerial_println(smooth);  //show filtered output of pot value
delay (100);
dxw00d
Coding Badly
First, let's review snippets from some of the replies...
I can't help but notice that the code you posted does not initialize smooth.  Do you think that might be the problem?
AWOL
smooth is initialised to zero by the compiler, so it is going to take a while to ramp up.
skyjumper
No, its not. Only static variables are initialized by the compiler. Non-statics will have a random value.
My question is, what is a reasonable value to initialize with?
AWOL
#13
Apr 29, 2012, 10:43 pm Last Edit: Apr 29, 2012, 10:47 pm by AWOL Reason: 1
It's a global; it is initialised to zero.
Happily, the float representation of zero is the same as int or long.
Grumpy_Mike
A reading from your pot. Do it in setup().
