Loading...
Pages: [1]   Go Down
Author Topic: Phototransistor  (Read 446 times)
Offline Offline
Newbie
View Profile
I would be grateful if someone could tell me how to use a phototransistor in a led circuit. smiley-lol
Logged
0
Offline Offline
Tesla Member
Arduino rocks
View Profile
Do you want the LED to illuminate the phototransistor or the phototransistor to drive the LED?
Logged
Offline Offline
Newbie
View Profile
I want the phototransistor to drive the LED.
Logged
0
Offline Offline
Tesla Member
Arduino rocks
View Profile
Well if you look at some of the examples you'll probably find a circuit using an ordinary NPN transistor to drive an LED, and the phototransistor should just replace the transistor.  Basically phototransistor emitter to ground, collector to current-limiting resistor for the LED (try 220ohm), other side of resistor to cathode of LED, anode of LED to +5V.
Logged
Manchester (England England)
Offline Offline
Brattain Member
Solder is electric glue
View Profile
WWW
Quote
Tricky because you might not be able to get enough current from the photo transistor to drive the LED.
I assume you want a circuit to light an LED when the photo transistor sees light?
Logged
Offline Offline
Newbie
View Profile
Yes, i want to light a LED when the photo transistor sees light.
Logged
Offline Offline
Brattain Member
View Profile
WWW
Try this:-
Logged
Offline Offline
Newbie
View Profile
What is the 100K and the BC108 at the circuit?
Logged
Offline Offline
Brattain Member
View Profile
WWW
Quote
What is the 100K
It is a resistor.
Quote
the BC108
It is a transistor, but any general purpose NPN transistor will do.
I feel if you have to ask these questions then the project might be beyond you at this stage in your knowledge.
Logged
Ontario, Ohio
Offline Offline
Full Member
View Profile
Are you using the photo transistor as on/off only? You may be able to do an analog read from the emitter pin to detect your desired amount of light, then use a separate pin digital pin from the arduino to turn on/off the LED. That would solve your current problem. It would also allow you to adjust the brightness of the LED if you desire by using one of the pwm pins of the arduino to drive the LED. If you're not sure how to do this in detail, and you can't find out by searching, I (and others) would be glad to help. (hint: show some evidence that you have researched/learned something since your last post)
« Last Edit: April 29, 2012, 07:21:14 am by TeslaIaint » Logged
Pages: [1]   Go Up
Print
Jump to:
