Topic: Attiny 85 RF (Read 4088 times) previous topic - next topic
mitko
Hello,guys can you tell me how to run virtualWire under attiny85 ?
I am using this RF :
http://www.robotev.com/product_info.php?cPath=1_30&products_id=235
Erni
Tinywire ?
http://www.arduino.cc/playground/Code/USIi2c
mitko
Is there something else I can use ?
Coding Badly
http://arduino.cc/forum/index.php/topic,63755.0.html
mitko
#4
May 02, 2012, 09:43 am Last Edit: May 02, 2012, 09:49 am by mitko Reason: 1
Well I tried this manchested library, but I always get this error when I try to upload the code in attiny85 :
Code: [Select]
#include "MANCHESTER.h"
#define TxPin 1  //the digital pin to use to transmit data
unsigned int Tdata = 32;  //the 16 bits to send
MANCHESTER.SetTxPin(TxPin);      // sets the digital pin as output default 4
}//end of setup
//Tdata +=1;
MANCHESTER.Transmit(Tdata);
delay(100);
}//end of loop
Code: [Select]
D:\arduino-0022\libraries\MANCHESTER\MANCHESTER.cpp: In constructor 'MANCHESTERClass::MANCHESTERClass()':
D:\arduino-0022\libraries\MANCHESTER\MANCHESTER.cpp:42: error: 'TCCR2A' was not declared in this scope
D:\arduino-0022\libraries\MANCHESTER\MANCHESTER.cpp:43: error: 'TCCR2B' was not declared in this scope
D:\arduino-0022\libraries\MANCHESTER\MANCHESTER.cpp:44: error: 'TIMSK2' was not declared in this scope
D:\arduino-0022\libraries\MANCHESTER\MANCHESTER.cpp: In member function 'unsigned int MANCHESTERClass::Receive()':
D:\arduino-0022\libraries\MANCHESTER\MANCHESTER.cpp:85: error: 'TCNT2' was not declared in this scope
D:\arduino-0022\libraries\MANCHESTER\MANCHESTER.cpp:126: error: 'TCNT2' was not declared in this scope
Erni
#5
May 02, 2012, 10:43 am Last Edit: May 02, 2012, 10:52 am by Erni Reason: 1
The TX part of the example is meant to be used with a 328 processor and the RX part on a attiny85.
What you are trying is to use 328 code on a Attiny85 (the tny dos not have a Timer2)
mitko
Ok so then how to upload succesufully the code on attiny85 then ?
mitko
Coding Badly
One reason for the lack of response is the inappropriate section you chose.  Let's try it here...
mitko
Ok,thank a lot , and sorry for my mistake
mitko
jonmcosgrove
I am using a different transmitter (433MHz from sparkfun) but I've had luck with the components listed below.
- IDE 1.0.5
- Virtual Wire 1.16
- ATtiny Cores from here
    -rename text file to boards.txt
- Load the bootloaded for 8MHz from the boards menu once the cores are installed in your sketch/hardware/attiny folder
Check out this link for help if you haven't seen it. I didn't have luck with their cores though.
