Loading...
Pages: [1] 2   Go Down
Author Topic: Mega Baud rate Error  (Read 1932 times)
Offline Offline
Newbie
View Profile
Having an problem with the 14400 baud rate on an Mega Board.
With Serial1 Tx Connected to Rx the following code works on 9600 and 19200 baud rates
but on 14400 the pulse width varies from bit to bit (from 50 to 100 uSec)
void Setup()
  Serial.begin(14400);
  Serial1.begin(14400);
  if( Serial.available())
      int inByte = Serial.read();
      Serial1.write(inByte);
  if(Serial1.available())
      int inByte = Serial1.read();
      Serial.write(inByte);
« Last Edit: April 29, 2012, 02:36:24 pm by T3bear » Logged
Global Moderator
Dallas
Offline Offline
Shannon Member
View Profile
WWW
How did you arrive at that conclusion?
Logged
Offline Offline
Newbie
View Profile
I was watching the input and output pulses on a scope.  The pulse width seems to right and consistent for 9600 and 19200 baud.
Logged
Offline Offline
Newbie
View Profile
More Information->
I modified the code to send and receive on Serial. only at 14400 baud
loop()
  if(Serial.available()
     int inbyte = Serial.read();
     Serial.write(inbyte);
Results->
Using the Serial Monitor->
sending 'r' or 'y' the return is 'r' or 'y'
sending 'R' or 'Y' the return is 'r' or 'y'
Upper case is returned as lower case
sending a string of characters return trash
again other baud rates work fine
Logged
Netherlands
Offline Offline
Tesla Member
In theory there is no difference between theory and practice, however in practice there are many...
View Profile
I recall some trouble with 57600 baud .. but no other.
Which IDE are you using 1.0, 0.22, 0.23?
have you tried another version of the IDE?
Logged
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
Offline Offline
Newbie
View Profile
I am using IDE 1.0, will give another a try.  Thanks
Logged
Offline Offline
Newbie
View Profile
I tried IDE 0022 and got the same results
Also tried 3 different Mega boards
and 3 different Uno boards
14400 baud always the problem.
Logged
Global Moderator
Dallas
Offline Offline
Shannon Member
View Profile
WWW
What is the full frame time (start bit to stop bit) of a byte leaving the processor (pin 1 on the Uno)?
Transmitting a zero will make the measurement easier...
Code:
void loop( void )
  Serial.write( (byte)(0x00) );
  delay( 1000 );
Logged
Offline Offline
Newbie
View Profile
Overall byte times @ 14400 baud>
Overall time of a byte from PC/SerialMonitor = 875 uSec
Overall time of a byte from UNO to PC/SerialMonitor = 835 uSec
The transmitted bits from the UNO are shorter than the bits from the PC
Logged
Global Moderator
Dallas
Offline Offline
Shannon Member
View Profile
WWW
What frame time do you get at 9600 baud?  What about 19200?
When sending a zero byte, is the frame is a continuous low signal?
Logged
Offline Offline
Newbie
View Profile
New byte times for 14400 baud:
The Uno Tx pin is high is goes low for 625 uSec then return high(the previous value was in error)
on incoming from PC the Rx is high and goes low for 725 uSec before returning high
For 9600 baud
Tx time = 975 uSec
for 19200 Buad
Tx time = 460 uSec
Logged
Global Moderator
Dallas
Offline Offline
Shannon Member
View Profile
WWW
Perfect match (625.5us is the expected value).
Quote
Corresponds to 12413.8 baud.
Good news: The code on the Uno is correct.  Bad news: The code on the ATmega16U2 has a bug.
Logged
Offline Offline
Newbie
View Profile
what is the next step?
unrelated question:
Is it possible to read/write a block (8 bits) of digital ports in one command?
Thanks for your help
Logged
Netherlands
Offline Offline
Tesla Member
View Profile
Quote
unrelated question
Yes it is called direct port manipulation - http://www.arduino.cc/en/Reference/PortManipulation -
Logged
Rob Tillaart
Global Moderator
Dallas
Offline Offline
Shannon Member
View Profile
WWW
If you want it fixed quickly, you will probably have to do it yourself (or hire someone).  I believe the problem is with the SERIAL_2X_UBBRVAL macro called here...
https://github.com/arduino/Arduino/blob/master/hardware/arduino/firmwares/arduino-usbserial/Arduino-usbserial.c#L209
If you want the problem fixed in future boards, I suggest reading how others have sought redress..
http://arduino.cc/forum/index.php/topic,64256.msg479323.html#msg479323
At a minimum, please report the problem here (include a link to this topic)...
http://code.google.com/p/arduino/issues/list
If you remain unsure how to proceed, report back.  Maybe someone else can offer better advice then I've given.
Logged
Pages: [1] 2   Go Up
Print
Jump to:
