Topic: [SOLVED] ETHERNET SHIELD r3 Problem (Read 917 times) previous topic - next topic
sirkle
May 10, 2012, 05:09 am Last Edit: May 10, 2012, 06:26 pm by sirkle Reason: 1
UNO r3 and ETHERNET SHIELD r3
I have checked everything I can think of used router, direct connection and all of the examples cause me problems. The chat server when connect endlessly spits out charters after it connects as well as the telnet client.The web server examples never display anything but a blank page. I am not new to microcontrollers but I can not figure this out. Do I have a bad shield? Can anyone comment on this problem I have tried diffrent line type setting auto scroll ect in serial monitor. Below is a picture of telnet client conneted
SurferTim
What version IDE is that? The versions prior to V1.0.1 had a bug in the ethernet library that would continuously spit out lines of characters over and over forever.
You can try one of two things.
Upgrade to IDE v1.0.1
http://arduino.cc/pipermail/developers_arduino.cc/2012-April/006444.html
or
patch the bug in your current version. Here is the report with the patch.
http://code.google.com/p/arduino/issues/detail?id=605
sirkle
Thank You that fixed my problem.... :)
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
